    Mar 2010
    7
    RNS-E Firmware Question
    Hi,
    I have a RNS-E headunit retrofitted to my audi a4 b7. It also has a BT module retrofitted and reverse camera and i would also like to activate the SDS function on it.
    Could someone please advise what software version i need to enable all the above functions. I might add that it is a european unit and at present everything has been coded in but the TV function does not appear in the CD/TV menu. I might also add the unit is pre 2010.
    At present the unit is SW:0650.
    27,126
    It needs the sds firmware which is usually labelled 0660 & wiring changed.
  1. 2011 RNS-E firmware question?
    By Tracebuzta in forum Satellite Navigation
    Last Post: 18th October 2011, 10:52
  2. RNS-E Firmware?
    By Khufu in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd September 2008, 19:42
  3. RNS-E parts question
    By Crazypete00 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2007, 12:09
  4. RNS-E install question
    By Sinny71 in forum In-Car Entertainment
    Last Post: 13th February 2007, 09:33
  5. RNS-E Retrofit questions?? Suppliers etc?
    By Beddie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th December 2006, 21:18
Tags for this Thread
