Monster MotorsportEM Tuning
    benjie's Avatar
    Oct 2009
    Swindon - home of the 'Magic' Roundabout.
    645
    B6 A4 RNS-E and Colour DIS - no nav info displayed.
    So I have a 2003 B6 A4. I retrofitted a Colour DIS about 3 years ago and retrofitted RNS-E today. Only thing is, I can't get the disections to show on the DIS. I'm stumped. I have used VCDS and gone to 17 Instruments > Adaptations > Channel62 and added the nav to it (add 4) - switched off and on, keys out etc. But location data and nav info won't display.
    Is there something I've missed?
    B8 S4 Avant in Misano Red with some lovely toys!
    Prev: B6 A4 Saloon 1.9 TDI quattro Sport - great car.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,525
    try this
    set a route when its on
    turn nav on and off.
    see if it works
    27,120
    Should only affect red dis clusters, colour should work fine.
    Unplug the rns from the car & leave 10 seconds & plug back in, also check your rns coding is set to A4 & if the unit turns on/off with key in/out.
    benjie's Avatar
    Oct 2009
    645
    Thanks for the input guys. I have just come back to the car after an hour - I deliberately left the route guidance going. On startup, I get the normal fuel/mpg info in computer memory 1, memory 2, then another screen with an arrow showing direction of destination and how many miles away the destination is. Nothing else - my house is quite far away from the road and the nav thinks I'm 'off-road.' Is this right, is it showing everything it should?
    EDIT: Been for a drive, it knows where I am now and shows me the next turn, miles left, little bar on the right telling me how far the junction is. Pretty sure Ijust needed to give the car time to do the changes. Thanks guys.
  1. RNS-E and DIS retrofit question.
    By JAS11N in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th December 2011, 16:55
  2. RNS-e and SD cards
    By djhindley in forum In-Car Entertainment
    Last Post: 9th March 2007, 10:57
  3. Newbie questions for '07 A3 RNS-E and Bluetooth
    By verschuur in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th February 2007, 20:02
  4. RNS-E and lighting retrofit guides
    By The911SC in forum In-Car Entertainment
    Last Post: 5th February 2006, 09:50
  5. Latest Mods - Rieger Front, Valeo Projectors and Colour Coded Bumper
    By madkebab in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd September 2005, 20:23
