Results 1 to 9 of 9
Thread: Coding
    Apr 2013
    Kettering, Northamptonshire
    171
    Coding
    To code my rnse mk 2 I have put - 0215751 the sat nav works and displays on DIS, I don't have Bluetooth or a cd changer but I do have a flat bottom however this wont work, ive tried coding it but not sure if im doing it right, all I can get it to do is when I press mode and the speaking button it skips the track. Probably doesn't have the highline steering module. What does mess blocks, supp codes, adaption, adv ID and adv meas values do?
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Does your car have Bluetooth? It's not built into the RNS-E, it's additional equipment.
    If your car does have Bluetooth built in already then reset the RNS-E (Hold radio & Setup until the screen blanks)
    Apr 2013
    171
    No I don't have Bluetooth mate
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    So change the 7 to a 1 and reset the RNS-E
    Apr 2013
    171
    Cheers done that, how do I definitely if ive done it right? What are all the other buttons? What fakra connector do I need as mine is broken, probably why my radio signal wasn't very good, ive seen a couple of different ones on ebay, I had a look at it but one of the leads disappears so not sure what it looks like. Thanks
    Apr 2013
    171
    Right now discovered on my flat bottom the left hand side skips track one way and the wheel turns the volume up only if you press the wheel and opposite for the other side
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,571
    What's the part number of your Steering Module? Find in 16 - Steering Wheel.
    Sounds like you have a Steering Module which expects MFSW controls from a Golf.
    Audi A3 2.0TFSI S Line SE DSG
    JMB Retrofits - North East Retrofit Company
    Apr 2013
    171
    Just had a look at my a3 (2005) 2.0 TDI DSG I have flat bottom and planning on cruise, my steering module is 8P0 953 549 B and slip ring 1K0 959 653 C, I looked on Ross Tech for the steering module and its not listed
    Apr 2013
    171
    BUMP
  1. code 9141
    By tp7n in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th August 2003, 21:28
  2. Decipher Vehicle Data codes
    By wigginer in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd August 2003, 12:05
  3. SILVER A3 PAINT CODE
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th July 2003, 17:28
  4. A4 KEY CODE PROBLEM
    By anwar in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th June 2003, 18:13
