Monster MotorsportBadger5
    Feb 2012
    Audi A4 RNS e help
    Brought my mrs a genuine nav unit for her 2006 audi a4 I installed it fine but when I take the key out the ignition the unit doesn't turn off I have to turn it off manually.
    The old unit turned off when I took the key out.
    Any ideas
    Thanks in advance
    27,094
    It needs coding to the car in the 1st instance, as well as any wiring checked.
    Jun 2012
    Maidstone/ Plovdiv
    66
    Add nansi_2005 on Facebook
    Quote Originally Posted by vishmk1 View Post
    Any ideas
    Thanks in advance
    I put RNS-e in my A4 b5 2001 and has got the same problem !
    did you have your backlight on the buttons ?
    if no your car hasn't got CAN signal so you need to buy adaptor for it! I just order my one and can show picture when i put it on the car!
    Aswell my navi is switch off every 30 min!!!!
    i hope to help you this one
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    The first A4 B6/B7 does have can bus, it's a 2006 car, it's simply coding. Probably a hybrid A4/A3 combination that needs to be coded correctly for A4 to work.
    The B5 A4 again does have can bus on the 2001 model, but you should get it from the back of the cluster if it is not available on the wiring loom for the radio. Depends which radio you had fitted already. You don't need a canbus adaptor if you install it correctly.
    If it was built slightly earlier than 2001 then you may not have canbus available from the cluster and then you will need an adaptor to generate can messages.
    Feb 2014
    29
    Could anyone help me got a Navigation Plus into my audi please?!
    Using Tapatalk
  1. Audi A3 RNS-E aux help
    By x1prince1x in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th March 2013, 18:23
  2. Audi Navigation RNS-E A3 S3 DVD GPS Sat Nav HELP
    By scouse1980 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th January 2012, 20:47
  3. Audi Navigation RNS-E A3 S3 DVD GPS Sat Nav HELP
    By scouse1980 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th January 2012, 19:37
  4. Audi Navigation RNS-E A3 S3 DVD GPS Sat Nav HELP
    By scouse1980 in forum Satellite Navigation
    Last Post: 18th January 2012, 19:34
  5. RNS-E Audi S3 8P Mic help
    By rabs in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th May 2010, 06:41
