JMB RetrofitsAH Fabrications
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    551
    Add GeoffDunk on Facebook
    Question NAV guidance in Colour DIS
    Hi all,
    Probably a question that has been asked before so I apologise in advance.
    I recently upgrade to and RNS-E and its working out great. For some reason I thought I would get turn by turn display in the DIS between speedo and Rev-counter. Should this be the case and if so is VCDS required to activate this?
    I wasn’t sure if it was available on a B6 with RNS-E mk1.
    I gave a 53 plate S4 (B6) with 2008 RNS-E MK1 and colour DIS.
    Cheers all for reading!
    Regards,
    Geoff
    27,126
    If its coded properly with colour dis which S4 has, then should get nav data on the dis yes.
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    551
    Yep, I have full colour in the S4 as spec'd. I just need to find the right code, are they listed on here anywhere do you know?
    I have access to a guy with VCDS but would be helpfull if I can point him in the right direction before hand.
    27,126
    Well go into instruments 17 & adaptations & code into infotainment bus, if they have vcds they should know how to use it fella.
  1. fitting colour dis to standard dis car help
    By the jammy one in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th July 2012, 12:09
  2. Has Anybody done a colour DIS retrofit??
    By rob irl tdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th November 2010, 11:42
  3. colour dis retrofit?
    By paulsb in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th July 2010, 13:29
  4. Colour DIS
    By itsmeagain in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th May 2010, 21:41
  5. A3 Instrument Cluster With Colour DIS (Not Red)?? Part No. Req
    By fesss_84 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th December 2007, 14:35
Tags for this Thread
