AH FabricationsSky Insurance
    riggssuzuki's Avatar
    Jan 2012
    Elgin, Scotland
    444
    Problem copying SAT Nav to SD card
    Hi. I have a 2011 A4. I am trying to get the Sat Nav to run from SD card. I tried to copy it using the car system but kept getting failures. I therefore did the copy on my PC. I have checked all of the files are copied across. However when i put the SD card and try to run sat nav from it i just get something about the medium authentication being invalid. WHat is the best way to get the SD card working and how do i do it? Thanks peeps.
    2011 A4 2.0 TFSI Quattro Dynamik. IBIS White.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    I've done it 2 or 3 times, I used a 16 GB SDHC card and it worked perfectly everytime copying to SD card in the car.
    Jan 2012
    Elgin, Scotland
    444
    Quote Originally Posted by s8craig View Post
    How did you actually do it? I pløace the SD card in the slot and used the 'copy to' option but it didnt work. Then i formatted the SD card and tried via the laptop. It copied across fine but wouldnt work in the car.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    I just inserted the SD card and used copy facility, that's how I did it.
    Jan 2012
    Elgin, Scotland
    444
    Is there a specific requirement for SD card type?
  1. Sat Nav Plus SD cards?
    By d5aul in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th August 2007, 17:52
  2. Sat Nav problems
    By trekbiker in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th May 2007, 11:29
  3. Sat Nav+ max SD Card Size?
    By A3_3.2_S-Line in forum In-Car Entertainment
    Last Post: 18th August 2006, 14:33
  4. 1GB MP3 SD card in Sat Nav+
    By imported_MatMc in forum In-Car Entertainment
    Last Post: 27th September 2005, 18:09
  5. Phatnoise/Sat Nav Plus with SD card
    By Eeef in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th December 2004, 19:00
