AH FabricationsEM Tuning
Thread: HELP nav plus??
    Don's A3 TTu's Avatar
    Nov 2008
    Surrey
    316
    HELP nav plus??
    i have a 54 plate 3.2 quattro and the previous owner fitted RNS-E and 6 disc changer but the rear speakers, sat nav and radio dont work i took some pics wondering if you could shed any light on the issue
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    A couple of things I can see straight away. That brown/mustard coloured connector is the radio diversity signal, not the GPS antenna where you have inserted it. That really needs moving to the dual antenna connector at the bottom left of the RNS-E. right hand one is the diversity, left is the HF signal. The top right is GPS and you need a GPS antenna to plug into it.
    Secondly your adaptor wire doesn't have the essential part to connect the rear amp to the RNS-E. That is why you have that 20 pin connector with nothing plugged into it.
  1. Sat nav plus system not working please help.
    By daveturbo in forum Satellite Navigation
    Last Post: 9th March 2012, 11:34
  2. Help! 2003 Audi Sat NAv plus stuck in safe mode!
    By eddie659 in forum RS6 Forum
    Last Post: 14th September 2009, 21:57
  3. Audi Sat nav plus RNS-E Bose HELP !
    By Whiteatom in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th June 2008, 21:55
  4. Urgent help needed with value of sat nav plus
    By imported_Tariq in forum In-Car Entertainment
    Last Post: 23rd November 2004, 17:07
  5. sat nav plus upgrade!! help needed urgent (please)
    Last Post: 18th November 2004, 14:59
