    Aug 2012
    What version do I have 2G or 3G MMI
    After reading how to tell if my system is a 2g/3g I'm slightly confused. The dash screen is a 6.5" with 2 SD card slots and one Dvd drive, with one single large button. All this suggests a 2G system but the Navigation disk is 3G!
    If this is a 3G system why have I got a 2G button? Can I change it over or even add a hard drive ?
    Reason I am asking which version I have is because I brought a disk from satnavi.com and unfortunately I think I brought the 2G version and its not working.
    Any info to narrow it down will be appreiciated
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    You have 3G Navigation low, also from 2011 all disks have to be activated by a dealership in 3G systems. So if you buy a disk from ebay or other sources you will have a problem to get it working as it comes with an activation key and SVM code that need to be entered when the update is done at the dealrship.
    Aug 2012
    Thanks for the info, could the system be upgraded to the higher version ie hard drive and the joystick button with new navigation software? Avoiding Audi itself.
    Quote Originally Posted by s8craig View Post
  1. What car did you have before S3? and what next?
    By cliowilliams in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd April 2008, 09:08
  2. What Gearbox do you have ?
    By spiider in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th December 2004, 16:22
  3. How do i find out what model engine i have????
    By Markey in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th November 2004, 23:27
  4. What Pressure Do U have on Ur GSD3's
    By kchow in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th November 2004, 08:40
  5. still having problems.. what wheels do you have?
    By richy in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th April 2004, 18:56
