Badger5Volks Autos
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Question RNSE Firmware Version
    I've fInally got round to installing my RNSE Mk2 this weekend & while it all seems to work perfectly I decided to check the firmware version which is showing it as being 0200, now correct me if I'm wrong but this is well out of date & for the US not Europe?!
    So my question is what is the latest firmware version, & how do I update to it (I have a 2011 maps disc if it's of any use)?
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    max69vk's Avatar
    Apr 2012
    745
    Just had a thought, I'm probably getting the firmware & software versions mixed up. Do I check the firmware using VCDS?
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    0200 is for MK2 units EU units, software 0650 was the last MK1 software version.
    Your unit looks like a MK2 to me.
    I'm pretty sure the 2012 disk only has 0200 on it as I have one in my car.
    27,096
    Yeap still on 0200 on 2012 dvd's.
    max69vk's Avatar
    Apr 2012
    745
    Thanks for confirming Nigel
  1. PDA version of VAG-Com....VAG-Check
    By Gambba in forum VCDS (formerly VAG-COM) forum
    Last Post: 14th January 2009, 09:09
  2. Replies: 3
    Last Post: 7th November 2005, 16:29
  3. Removing headunit from audi A3 2000x (symphony version)
    By belabed in forum In-Car Entertainment
    Last Post: 22nd July 2005, 22:49
  4. Coil Packs on S3 - Version G
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th November 2003, 18:11
  5. audis Holy Grail aka ETKA euro version
    By s3tle in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th January 2003, 21:06
Tags for this Thread
