AH FabricationsSky Insurance
    kolash's Avatar
    Dec 2011
    London
    44
    Correct codes for RNSE with factory bluetooth phone
    Hi
    We have retrofitted an RNS-E to my 2008 A3 sportback. The unit states that "telephone is not installed". I have factory bluetooth with GSM prep in the arm rest.
    In VCDS there are a number of code options:
    § 0xxx?xx: Telephone/Telematic
    § 1 = Telephone not installed (Remote Feed Voltage for Microphone active)
    § 2 = Base Plate (Temic - Remote Feed Voltage for Microphone inactive)
    § 3 = Base Plate (Cullmann - Remote Feed Voltage for Microphone inactive)
    § 4 = Base Plate (Nokia - Remote Feed Voltage for Microphone inactive)
    § 5 = Telematic Europa (Remote Feed Voltage for Microphone inactive)
    § 6 = Telematic US (Remote Feed Voltage for Microphone inactive)
    § 7 = Base Plate diagnostic capable with Comfort Control
    Which is the correct one for the bluetooth I have?
    Hope someone can help!
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    In the voice of Len Goodman "Severn"
    But you should also recode your phone module to 0011422
    kolash's Avatar
    Dec 2011
    London
    44
    Quote Originally Posted by s8craig View Post
    Many thanks, after 1, 7 is one I thought least likely to be correct!!
    Yes had guessed the phone needed recoding too, and had noted that exact code.
    Will hopefully try it out tonight.
    kolash's Avatar
    Dec 2011
    London
    44
    All works perfectly now, thanks mate!
  1. Good news for Nokia N/E series phone owners with Bluetooth
    By s8craig in forum In-Car Entertainment
    Last Post: 3rd June 2007, 20:12
  2. Q for folks with factory fit cruise control..
    By Tooks in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th January 2007, 15:47
