Badger5Volks Autos
Results 1 to 15 of 15
    May 2012
    North London
    11
    Post RS4 RNS E 2011 upgrade DIS not working
    Hi all,
    Just upgraded the current RNS E system installed in my B7 2007 RS4 to a later RNS E 2011 model. Physical installation was simpler than I expected as it was merely plug and play. I have the factory fitted CD changer and Bose setup. Everything works perfectly but the only problem I've encountered is that the navigation/cd/radio information no longer appears on the DIS. The top portion of the DIS is constantly blank. Is there something I've missed? Does the car need coding in order to communicate with the new RNS E unit? Does the unit need to be reset? Any help would be very much appreciated. Willing to pay any helpful soul to fix the problem. Was also looking to have Bluetooth installed into the car as well, so any recommendations for installers would be useful.
    Oz
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    As they never made an A4 unit in the 2010 RNS-E it's probably an A3 unit with an A4 faceplate and still coded for A3 which explains the lack of DIS, probably doesn't turn on and off properly either. Get it coded for A4 and it solve all your problems.
    May 2012
    North London
    11
    Hi Craig,
    Thanks for the helpful response.
    Any idea what I need to change coding wise or know anybody who could help? I've used VCDS before when I owned a Golf GTi MK5 and a Micro CAN cable. If I can't find anyone to help, I guess I need to invest in a Hex CAN cable and code it myself. Any useful pointers?
    Thanks again!
    27,073
    Whereabouts are you located, as helps us to advise you
    May 2012
    North London
    11
    Oops! I'll update my profile. I'm based in North London but happy to travel and/or pay if anyone can help!
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    Well you're in luck mate, because Nigel (NHN) can sort out your coding issue on your unit AND sell you a genuine VCDS interface lead
    2012 RNSe Navigation Discs with unit software update. PM me.
    Suzuki GSX-R 750 K5
    A4 S-Line. Mods so far; Cruise, DIS, Mk2 RNS-e, Audi 6 CD changer, XcarLink with self manufactured permanent ipod dock, B8 MFSW, Dectane Dayline Headlights with independantly switched DRL's, RS4 Rear ARB, De-badged, RS4 pedals, HIDS, RS4 front grille and RS4 style fog surrounds, LCR splitter in Satin Black, Rear Park Assist, LED gearknob, Red footwell lighting, Kitchen sink and Shower cubicle.
    May 2012
    North London
    11
    Excellent! I've already contacted Nigel for a VCDS cable. Hopefully he'll be able to help with the RNS E coding.
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    No hopefully about it, if he gets involved, consider it done
    Suzuki GSX-R 750 K5
    May 2012
    North London
    11
    Great! He must be quite busy at the mo as I haven't received a response! Hopefully he'll be able to help.
    27,073
    Quote Originally Posted by OzMaq View Post
    Sorry for delay mate, will ping invoice over shortly, just dealing with some technical things, namely my daughter wanting to feed toys into a vcr of my outlaws, amongst other technical duties you understand, lol.
    TBF Craig IMHO was right in 1st instance, coding for A3 should fix it, but other coding options will no doubt be required, email to follow
    May 2012
    North London
    11
    Cheers, Nigel.
    I completely understand the kids issue. My daughter is constantly attempting to feed my Xbox with crackers. Ah well, at least she gets more use out of it than I do these days! Lol
    Johnny Bravo's Avatar
    6+1 Gears
    Jun 2009
    Romania
    797
    Hi QzMaq!
    Did you managed to fix your problem? I have the same issue with a mk2 rnse from a A3 fittetd on a A4.
    Can you tell me what coding is required?
    The unit was previously fitted and coded on a A3 and swapped the faceplates to fit the A4.
    Thank you!
    DSG | Vienna Leather | Bose Sound | MFSW | Interior Lights Pack | Light & Rain Sensors | Auto Dimming Mirror Mods: LED RNS-e | FL LED Tail Lights | Bi-Xenons | Illuminated Speaker Grilles | Tinted windows | Chrome Switches | Chrome Paddles&Commands | RS4 Start Button | Cruise Control | S3 Pedals | S3 Roof Spoiler | 18" BBS CH | H&R Spacers 10/15 mm | Bilstein B16 PSS10 | H&R 26/24 ARBs | TT Arms | S3 Front Brakes+DS2500+Tarox F2000 | HEL Brake Lines | VNT20 | EGR&Cooler Delete | Custom Remap
    May 2012
    North London
    11
    Hi buddy,
    It was really easy in the end. Just needed to recode the unit via VCDS. I've got a web link somewhere. You'll have to buy or borrow a VCDS cable to do the necessary. Send me a PM and I'll send you the link with the necessary coding information. Just have to change one bit and that's it.
    Oz
    27,073
    Make sure the rns is enabled on the bus in instruments adaptation channel & rns coding is for A4 as stated already on this thread.
    May 2012
    North London
    11
  1. Replies: 0
    Last Post: 20th September 2011, 22:00
  2. retro upgrade q7 2011 sound system
    By pravinkumar in forum Q3, Q5 & Q7 Forum
    Last Post: 9th September 2011, 01:43
  3. RNS-E Upgrade from 2009 Sat Nav disc to 2011 Sat Nav disc
    By pluves1 in forum Satellite Navigation
    Last Post: 23rd June 2011, 19:19
  4. Tail Brake lights not working, but the 3rd one is working.
    By sixsr in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th February 2009, 12:42
  5. New 'RS4' bumper for B6 cabriolets !
    By andyccr in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th September 2008, 21:52
