Chris NottVolks Autos
Results 1 to 7 of 7
    amimmortal's Avatar
    Jul 2004
    Dunfermline
    226
    Intermittent loss of Satellite Signal & no AM reception
    Hi all...
    A while back I posted about a loss of satellite signal on my RNSe Sat Nav plus system in my A6 C5 avant. The AM reception has been missing for a good while, but I'm starting to miss it now and I think the two issues may be connected.
    The gps connection came back (so I attributed the loss to the solar flare, no less...) and worked for a few months without any problem, but it has now failed again.
    I took the car into an Audi specialist today and they ran a VGC scan on the system. They found no errors with the GPS or the radio antenna.
    But, the unit was struggling to pinpoint me, alternating between 0 and 3 satellites on my way home from work. Normally, it finds 8 or 9 satellites and has no problem. It's currently sitting at 0 satellites outside my house, with my position about a half mile off.
    I was doing a search online and found something about an antenna booster, mounted in the tailgate. I think the part number is 4B9035225B, but I'm not certain.
    If this were faulty, would this cause the problems I'm experiencing?
    If not, does anyone have any other ideas?
    The antenna is also in pretty bad shape - the rubber is all perished at the base and I don't know if the wire itself is still in good condition. The garage did open up the panel under the antenna, where the boot light is located, and they found it bone dry with no visible issues.
    Any help would be much appreciated as I miss my satnav terribly...
    Thanks!
    A.
    27,114
    You could try adding the smaller square gps antenna, see if this helps with the signal, if so then it would indicate the antenna system has a fault somewhere, I think there's an antenna amp in the boot lid somewhere, but I wonder if its the roof antenna as the wiring schematics seems to indicate R52 as the roof aerial for radio, telephone & navigation.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    With the A6 Avant the roof antenna is GPS/GSM/FM/AM according to ELSAwin, The exact would depend on what options your car has. It can be FM/AM (simplex) or FM/AM/GSM & FM/AM/GPS (Duplex) or FM/AM/GPS/GSM (triplex).
    Usually the base fails which is the antenna amp and the GPS, maybe you should swap that.
    27,114
    Glad Craig confirms what I read, everydays a school day for me
    amimmortal's Avatar
    Jul 2004
    Dunfermline
    226
    Thanks S8Craig
    Mine has the RNSe sat nav but no phone preparation. Would that make it FM/AM/GPS?
    Does ELSAwin say where the components are installed?
    Also, is anyone able to explain why the GPS needs a specific bee-sting aerial? I would have thought these would be separate?
    Thanks!
    A.
    amimmortal's Avatar
    Jul 2004
    Dunfermline
    226
    Update:
    I've bought a fakra GPS antenna off e-bay and the RNS-e removal keys (set of 4). I've also had a look at some pictures and videos on youtube to see how to demount the glove compartment, behind which I gather is a good place to mount the magnetic antenna.
    Obviously, if the satnav starts to work with the new antenna, I know it's the factory installed antenna (or one of the boosters) that;s faulty.
    Having said that, I'd still like to try getting the AM reception back, which this obviously won't address.
    Does anyone have any ideas?
    Thanks,
    A.
    amimmortal's Avatar
    Jul 2004
    Dunfermline
    226
    Just completed installation of the new GPS antenna.
    I demounted the glove box and attached the magnetic antenna on a piece of the dashboard frame. I'm getting 5-6 satellites now, and it's been able to pinpoint my position no problem.
    Really pleased with the result.
    Now I just need to sort out the intermittent loss of sound from the rear speakers...
    A.
  1. Intermittent radio reception
    By polar in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st September 2010, 10:33
  2. Intermittent Radio Signal - 2005 A4 Cab - Please Help !
    By Lord Bigfoot in forum In-Car Entertainment
    Last Post: 22nd May 2010, 19:26
  3. Sat Nav Satellite reception stopped
    By Alexander in forum Satellite Navigation
    Last Post: 20th January 2010, 11:06
  4. A4 1.9TDI - intermittent loss of power
    By chuffy in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th January 2008, 00:09
  5. New rear screen - loss of radio reception??
    By stupot in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th April 2006, 09:09
