Volks AutosMonster Motorsport
    Jan 2011
    570
    Upgrade to newer RNS-E - thoughts?
    Hi guys,
    I retro fitted an RNS-E system with factory bluetooth to my 52 plate quattro a couple of years ago now, however I am toying with the idea of upgrading it to a newer unit as fitted to the current A3, mainly from the point of view of having the LED screen and the ability to use SDHC cards as the new units will handle up to 32Gb if I remember correctly.
    Obviously I would need to swap over the fascia's (how difficult is this??) but what is everyone's thoughts? Is there anything else a newer unit would add such as voice control? (I do not have a multi function wheel on the car) Should I go for a specific version number??
    Cheers in advance
    Steve
    03MY 52 reg 1.9 TDi 130PS Quattro Sport Avant - 170bhp remap, RNS-E+OEM bluetooth, B7 wiper arms/blades, 4300K HID+nightbreakers/LED sidelights, rear tints, new lights all round, new front/rear screens, frt armrest, s-line kit, cruise/DIS, B7 gearknob/aluminium trims, parking sensors, black grilles, RS4 RARB, S4 front end, black 18" RS6 alloys
    Still waiting..... S4 rear bumper, exhaust tips, coilovers, leather recaro's.... phew...
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    It won't work, the new RNS-E cannot be coded to A6 mode and therefore will not pick up the speed pulse. You will need to buy a cangate module from Bjarne in America and code the unit to A4, that is if the A3/S3 8L produces speed pulse over can. Everything will work except for the road speed indications.
    I have one working in my 2003 A2 that way.
    Jan 2011
    570
    It's an A4 I have..... can't understand why the new units would use a different speed pulse when they are also fitted to Seat Exeo's which is essentially a B6/7 platform....
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    If it's an A4 then it will work except for the road speed indication, sorry I thought you had an A3 8L
    You don't need to swap faceplates over as you can buy A4 LED units (already swapped basically) and you can use an EXEO if you want to.
    Jan 2011
    570
    S8craig....
    I got the slightly longer reply drop into my inbox before I came back here, so let me just get this correct....
    I am looking to get one of the new (PU?) units, looking at an A3 unit as they are cheaper than the Seat Exeo ones (by about £300) hence why I am looking to swap faceplates..... am I correct in stating that the new units do NOT use can-bus for speed indication and use the older style GALA system that they used on the RNS-D units in the old A6/A8 models? This would seem to be step backwards surely...... If I do need to buy a cangateway from the US what are the costs?
    I was hoping to just unplug one unit, swap faceplates and then re-install new unit and code, if it's going to be any more hassle than that then I won't bother.....
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    No they use the speed signal over can bus same as before. It will be plug and play with an A3 unit if you change the faceplate and code it to A4. Sorry for the long confusing explanation (rant) of the RNS-E in an older car.
    The speed signal over canbus in my A2 is not enough to drive the new RNS-E, but the cangate converts it to GALA over canbus and it works.
  1. Upgrade BNS 5.0 / RNS-Low with RNS-E
    By markhaines in forum In-Car Entertainment
    Last Post: 29th January 2012, 21:41
  2. rns-c upgrade
    By Pete Wilde in forum Satellite Navigation
    Last Post: 15th September 2011, 20:52
  3. RNS-D to RNS-E upgrade, old stuff I know but help needed in Technophobe speak please
    By Bluevane in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st May 2010, 09:41
  4. Q about upgrade to RNS-E (8P)
    By Issac Hunt in forum In-Car Entertainment
    Last Post: 28th February 2007, 18:34
  5. Newer RNS-D Sat Nav Software CD's?
    By imported_Stewart in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2006, 23:44
