AH FabricationsEM Tuning
Results 1 to 10 of 10
    Mar 2012
    7
    RNS-E S/W Upgrade question - New to the Forum
    I have an Audi 3.0 Quattro (54 reg) with an RNS-E headunit and need to know what I need to buy.
    I've sort of got an idea from some of the posts on here. The S/W Version is 0550, HW is H99 and Map is M1N061018_EN0603 (Understand that the maps have nothing to do with the s/w upgrade). What I need to know is:
    1. What S/W version can I upgrade to (i.e Can I go straight to the latest S/W version or is there an upgrade path ?)
    2. I also want to enable the aux port so I can use a 3.5mm Jack on an iphone and is there any coding required (Not sure if 0550 lets you do this ?)
    3. Is updating the software simple as putting the DVD Rom in the drive and letting it run ?
    Many Thanks
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    SW 650 is the highest and will never be superceded on the MK1 RNS-E.
    Enabling the AUX port can be done with VCDS, so yes coding is required
    Yes, simply insert the latest DVD and let it run through updating twice.
    Mar 2012
    7
    Thanks for the response.
    Can I enable the aux ports with my current 0550 software ?
    Also i'm assuming all I need to enable a 3.5mm Jack via aux is a kit like this + VCDS Coding:
    MULTIMEDIA INTERFACE AUDI RNS-E A3 A4 A6 adapter 0003 | eBay
    26,720
    Quote Originally Posted by dmistry21 View Post
    Not entirely true as the fw is stored on the map dvd, unless you've downloaded the fw from another source.
    Mar 2012
    7
    Didn't know that. So i'm guessing I can upgrade the S/W via a CD-R or a new Map DVD ?
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    The kit you showed is not an AUX input for the 3.5 mm, that is an AUX video adaptor, a different concept entirely.
    What you need is this
    KUFATEC GmbH & Co. KG - AUX IN - Jack - Retrofit - Audi RNS-E 37898
    Mar 2012
    7
    Quote Originally Posted by s8craig View Post
    Excellent, So just to confirm I will need the 0650 software to enable the aux port as 0550 doesn't have support ?
    Mar 2012
    7
    Smile
    I'm pretty sure the 550, 600 and 650 does have aux support but I could be wrong.
    Just ordered it Next step figure out how to fit it but cross that bridge when I get there...
    I'll attempt the VCDS programming with the 0550 S/W first and see how I get on.
    Thanks for the advice.
    Apr 2012
    20
    Hi dont wanna hijack the thread but will a rnse disc from a 2011 model car work on our rnse satnavs 2005 model cars?
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Yes it will
  1. Upgrade BNS 5.0 / RNS-Low with RNS-E
    By markhaines in forum In-Car Entertainment
    Last Post: 29th January 2012, 21:41
  2. Kufatec bluetooth upgrade for RNS E question.
    By Shane-Ireland in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th September 2010, 23:52
  3. Kufatec bluetooth upgrade for RNS E question.
    By Shane-Ireland in forum Satellite Navigation
    Last Post: 29th August 2010, 22:50
  4. RNS-D to RNS-E upgrade, old stuff I know but help needed in Technophobe speak please
    By Bluevane in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st May 2010, 09:41
  5. Another RNS-E & AMI upgrade question
    By sje_123 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th September 2009, 18:47
