Results 1 to 18 of 18
    Mar 2012
    London
    Unhappy Poor Radio Signal on RNSE
    Hi All wondering if somebody can help?
    I have a 56MY Audi A3 with factory fitted RNS-E Unit, since purchasing the car the radio signal was poor but now a few years later it is worse than ever, only picking up one or two local stations (all the BBC stations are picked up fine) I cant remember the last time i was able to pick up XFM :-(
    I have checked the connection on the back of the headunit but not sure where it runs to after that? Also I think it may be exclusive to Fm frequencies only.
    Any help on this would be greatly appreciated
    Dan
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,398
    Quote Originally Posted by danomorgan View Post
    Dan
    Hi Dan, welcome to ASN. I am sure one of the guys be long shortly to help you. Have a read through the faqs at the top of the page to see if there is any info in here of use to you. Post some pics up of the car. Enjoy the forum.
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,574
    Sounds like you need to upgradethe Amplifiers in the tail gate of the car as the RNS-E uses a different aerial system to that of the standard stereos, however this would only need to be done if your RNS-E was retrofitted.
    How sure are you that the RNS-E was fitted at factory?
    Audi A3 2.0TFSI S Line SE DSG
    JMB Retrofits - North East Retrofit Company
    Blackie's Avatar
    Feb 2004
    In a house
    634
    I,m glad you mentioned it. Mrs B,s Cab had a retrofit & the reception is also rubbish. What do i need to buy ?
    Mar 2012
    London
    I bought the car ex-demo from the Audi dealership & all the wiring to the RNS-E headunit looks factory so I would say pretty sure.
    I have the haynes manual for this model but it doesnt really show where the cables run for the Ariel? Are there any common faults related to the ariel that i should look at?
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,574
    All of the aerial stuff is in the boot trim.
    These are the parts KUFATEC GmbH & Co. KG - Aerial system - Retrofit - Audi A3 8P, but as you can see its only if you're going from a Symphony II+ (3) to a RNS-E.
    I'd get it on VCDS to check for any faults first, if you do need the above parts a "ZF to Ground" fault should be stored.
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,574
    Quote Originally Posted by Blackie View Post
    I don't know the part numbers for the A4 Cab I'm afraid mate
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    If it's factory fitted then no need to upgrade/change the antenna amps in the boot. They should be the correct ones already.
    I suspect that it may be connections to the boot that may be the issue, I would test the radio for faults with VCDS to see if any are present and maybe do test runs of new cables to the boot antenna module.
    I would also guess the same with the cab depending on it's age it's a well know fault for the antenna cables to break on the cabs as the wires pass through the boot hinges.
    Blackie's Avatar
    Feb 2004
    In a house
    634
    Cheers Craig
    ill run a check. The cab did have a single din and I upgraded to the double din and rns-e
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Well if it was singe DIN then it did have the right antenna config as it would have been a concert II with HF/ZF antennas, unless it was a chorus whoich would not have had the ZF
    Mar 2012
    London
    cheers for the replies, going to run the VCDS tomorrow & see how i get on... Will post up my results soon.
    Blackie's Avatar
    Feb 2004
    In a house
    634
    Quote Originally Posted by s8craig View Post
    Not a clue Craig. I know that the station reception is a bit ropey sometimes but on the whole it isnt too bad. Will it tell me on a scan what amp is fitted ?
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    No it won't tell what amps, but it will tell you if you have a bad connection to the boot with an open or closed circuit.
    Mar 2012
    London
    Ok so here are the VCDS findings.....
    Thursday,15,March,2012,20:08:48:36838
    VCDS Version: Release 10.6.3
    Data version: 20101206
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 22 25 37 42 44 46 47 52 56 76 7D
    VIN: WAUZZZ8P07A055200 Mileage: 65400km/40637miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 1010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 1010
    76-Park Assist -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H34 0070
    Coding: 0002042
    Shop #: WSC 06314 000 00000
    VCID: 41825980610F
    Part No: XXXXXXXXXXX
    Component: E0221 H07 0090
    1 Fault Found:
    01304 - Radio
    004 - No Signal/Communication - Intermittent
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 J HW: 1K0 907 951
    Component: J533__Gateway H12 0160
    Revision: H12 Serial number: 320010672683FA
    Coding: BD0F0F4A07000101
    VCID: 2E58123CC091
    2 Faults Found:
    01300 - Control Module for Navigation with CD-Rom (J401)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 61
    Mileage: 65254 km
    Time Indication: 0
    Date: 2012.03.13
    Time: 08:06:17
    01304 - Radio
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 61
    Mileage: 65254 km
    Time Indication: 0
    Date: 2012.03.13
    Time: 08:06:17.
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 192 H HW: 8P0 035 192 H
    Component: RNS-E HIGH EU H72 0650
    Revision: 01S Serial number: AUZBZ7F0971933
    Coding: 0205117
    VCID: 346C00542EBD
    1 Fault Found:
    01305 - Databus for Infotainment
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 65
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 C
    Component: KSG H04 0050
    Coding: 198000403F3F8505489AC63300
    Shop #: WSC 00052 210 88667
    VCID: 3C7C287406ED
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    1 Fault Found:
    00332 - Control Circuit for Tank Flap
    007 - Short to Ground - Intermittent
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
    Part No: 8P0 959 802 H
    Component: Tuer-SG 020 0090
    Coding: 0000560
    VCID: 41825980610F
    1 Fault Found:
    00933 - Electric Window Motor; Passenger Side (V148)
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0205117
    VCID: 346C00542EBD
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 65
    Not entirely sure where to go from here?
    warren_S3's Avatar
    Oct 2007
    6,201
    Audi S3 Panther Black [2011] Build Thread
    Mods: Revo Stg2, Blueflame TBE, Eibach Pro springs, R8 oil cap
    On order: Audi S5 3.0V6T Coupe Black Edition, Phantom Black [Due 26 May 2014]
    Planned Mods: Revo Stg1+ with DSG map, Revo CAI, custom exhaust, H&R Trax spacers, EM Tuning LED interior lights, R8 oil cap, Porsche coolant & brake fluid cap
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Certainly not showing any antenna faults, it must be factory fit or it would be showing one fault.
    26,777
    Options now imho are to check all the coaxials front to back, the double connector that plugs in rear of rns sometimes one wire can become frayed, but this is usually from in/out all the time, but could check this, other option is to test rns in another car & vice versa.
    Mar 2012
    London
    Cheers Warren, had a look through your thread & then had an inspection of the Antenna system.
    After removing the boot trim to access the amps it is clear that the headUnit is factory as the amps & wiring are all (OEM looking) correct for an RNSE unit.
    I had a look at the looping on the back window & some of this was quite dirty where the trim normally covers it, this was cleaned with a dry cloth but still hasn't made any difference to my poor FM radio signal. (bit of a shot in the dark i know)
    I did notice after having a mess around with the headunit that this problem is exclusive to the FM waveband only.
    I unplugged the 3 way plug from the upper amp to see what happened & all Stations were lost, plugged back in & then unplugged the green & balck 2 way plug the other side that actually attaches to the back window, this didnt make any difference to the radio signal & Radio 1 was still working (only station i could pick up). Thought that this might have made a difference?
    I did take some pictures but not quite sure how to add them?
    Nigel, I will try what you said on Sunday if i get a chance..... I did read somewhere that it could be damage to the back window loop that could cause this? Although mine doesn't look damaged??
  1. Cab radio signal...
    By Louis Cronin in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st September 2012, 10:16
  2. help radio signal on concert radio
    By sam2681 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th January 2012, 17:23
  3. Poor radio signal
    By bigpkr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th July 2011, 12:46
  4. ALPINE X100 - Tuner signal POOR
    By audi18tdan in forum In-Car Entertainment
    Last Post: 6th October 2008, 14:37
  5. S3 Radio - no signal!
    By Spacecowboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th April 2008, 12:16
