JMB RetrofitsChris Nott
    Alex C's Avatar
    Lizard, Cornwall
    2,600
    2001 Audi S3 - RNS-D Satnav incorrect position
    Ok i have an S3 with the satnav as above in the title. I work in Falmouth in Cornwall and yesterday turned the satnav on and changed the display to show my position on the map. It showed me as being somewhere in Penzance and today whilst in Falmouth it showed me as being over in St Ives!
    I don't really know when the fault started but i only noticed it yesterday as i hardly use the satnav....
    What might be causing this error??
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Most probably the roof mount GPS antenna, easiest thing is to replace it with a GPS puck mounted just behind the cluster, should cost no more than £20. Make sure you buy a puck with an SMB and not a FAKRA connector.
    Remove the nav unit (make sure you have the radio code) and feed the cable from the GPS antenna from behind the dash to the nav unit, unplug the old GPS receiver and connect the new one.
    S3PEG's Avatar
    Bristol
    99
    Hi Alex, I had a similar problem last year. I was able to solve it by removing the unit from the centre console and securing a loose connection. Do you have a recent CD for your rns-d? I've been looking everywhere but can't find one available for download!
    S3Peg
    Black S3, APR Chip, EBC Brakes, 18" RSTT's.
  1. RNS-e S3 incorrect coding
    By Blackie in forum Satellite Navigation
    Last Post: 24th February 2012, 20:58
  2. RNS-D satnav for B6 A4
    By Az in forum For Sale/Wanted - Audi Parts
    Last Post: 22nd July 2011, 13:53
  3. RNS-E not remembering CD position?
    By Agent_Trig in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th March 2011, 18:55
  4. RNS-E, adding current position?
    By Andy H in forum Satellite Navigation
    Last Post: 3rd May 2010, 19:12
