DTUKJBS
    Nov 2011
    SE London/Kent
    29
    Post Thanks / Like
    Unhappy Help - RNSE Install from RNS 5
    Hi Chaps
    I really need your help please. I have spent all day trying to install the RNSE Sat Nav in my Audi A4 B7 2007 Cab.
    For weeks i have been reading all the forums etc to gather all the knowledge I needed but I am still having problems.
    I purchased this unit from ebay to replace my older RNS 5.0 which had the red monochrome display.
    I have installed the unit. Moved C7 to B5 for K-Line. Don't have Bose so didn't need to move any more wires.
    I looked at the coding and changed to what I thought it should be, at the moment it's 0433157. Obviously this is not correct but I am getting confused as to what they should be now! These are the faults i am getting. I have cleared these and tried numerous different codes, but still no luck.
    Saturday,28,January,2012,17:23:21:23493
    VCDS Version: Release 11.11.2 (x64)
    Data version: 20120126
    Chassis Type: 8H - Audi Cabrio B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 26 36 37 45 46 55 56 57 63
    65 67 73 75 76 77
    VIN: WAUZZZ8HX7K025642 Mileage: 77060km/47882miles
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 8E0 909 518 AQ HW: 8E0 909 018 B
    Component: 1.8L R4/5VT 0010
    Coding: 0011584
    Shop #: WSC 00672 785 00200
    VCID: 7F0674602DE65DB
    No fault code found.
    Readiness: 0000 1000
    Address 02: Auto Trans Labels: 01J-927-156.lbl
    Part No SW: 8E3 910 155 T HW: 01J 927 156 HT
    Component: V30 01J 1.8l5VT RdW 0010
    Revision: 00000009 Serial number: 00000001054070
    Coding: 0000001
    VCID: 39725A787342B3B
    Address 03: ABS Brakes Labels: 8E0-910-517.lbl
    Part No SW: 8E0 910 517 H HW: 8E0 614 517 BF
    Component: ESP8 FRONT H06 0140
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004872
    VCID: 2C5C732C8F10163
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 BL
    Component: A4 Klimaautomat 3233
    Coding: 00100
    Shop #: WSC 00672
    VCID: 6CDCB32C1C90D63
    Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
    Part No: 8E0 907 279 N
    Component: int. Lastmodul ECE 0907
    Coding: 20001
    Shop #: WSC 00672
    VCID: 3D7A4E68376A8FB
    Address 15: Airbags Labels: 8H0-959-655-94.lbl
    Part No SW: 8H0 959 655 E HW: 8H0 959 655 E
    Component: Airbag 9.42 H09 1840
    Revision: 92H09184 Serial number: 0037Y000LU7G
    Coding: 0071114
    VCID: 3C7C436C7F70863
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 Q
    Component: Lenks·ulenmodul 0701
    Coding: 02111
    Shop #: WSC 00672
    VCID: 418232984B92EBB
    1 Fault Found:
    01304 - Radio
    49-10 - No Communications - Intermittent
    Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
    Part No SW: 8H0 920 982 HW: 8H0 920 982
    Component: KOMBI+WFS 3 H10 0200
    Revision: 0200 Serial number: AUX6Z0F0084083
    Coding: 0006411
    Shop #: WSC 00546 210 91517
    VCID: EED83924FA8CA43
    1 Fault Found:
    01304 - Radio
    004 - No Signal/Communication - Intermittent
    Address 26: Auto Roof Labels: 8H0-959-255.lbl
    Part No: 8H0 959 255 A
    Component: VSG B6 CABRIO 7094
    VCID: 346C6B4C54204E3
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 193 B HW: 8P0 035 193 B
    Component: RNS-E PU EU H03 0210
    Revision: 0000005S Serial number: AUZBZ7K6104320
    Coding: 0433157
    Shop #: WSC 14109 211 17819
    VCID: 2F666420BD066DB
    1 Fault Found:
    03157 - Functionality limited due to Communications Disruption
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 113
    Time Indication: 0
    Date: 2012.01.28
    Time: 17:11:13
    Freeze Frame:
    Bin. Bits: 00000100 00000000
    Bin. Bits: 00000000 00000000
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8H0 951 178
    Component: Innenraumueberw. 0411
    Coding: 00001
    Shop #: WSC 00000
    VCID: EFE62420AD86ADB
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8H0 959 433 K
    Component: Komfortger·t T3B 5241
    Coding: 07855
    Shop #: WSC 00672
    VCID: 3C7C436C2C70863
    Subsystem 1 - Part No: 8H2959802D
    Component: Tırsteuer.FS BRM 0205
    Subsystem 2 - Part No: 8H2959801D
    Component: Tırsteuer.BF BRM 0205
    Subsystem 3 - Part No: 8H0959801A
    Component: Tırsteuer.HL BRM 0002
    Subsystem 4 - Part No: 8H0959802A
    Component: Tırsteuer.HR BRM 0002
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0433157
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 113
    Time Indication: 0
    Date: 2012.01.28
    Time: 17:11:13
    Freeze Frame:
    Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
    Part No SW: 8E0 919 283 D HW: 8E0 919 283 D
    Component: Parkhilfe 4-Kan H06 0010
    Revision: 00H06000 Serial number: 00067802030634
    Coding: 0001024
    VCID: 31626258AB327BB
    This is causing the unit to constantly keep rebooting, and the sat nav function just keeps locking up. I thought this might be to the unit having troubles reading the DVD, but it is an original DVD disk.
    Any help would be much appreciated as I'm just about giving up now.
    Just to recap, I don't have Bose, I do have MFSW and I do have colour dis which these were working with the old BNS 5.
    Many thanks
    Andy
    Nov 2011
    SE London/Kent
    29
    Post Thanks / Like
    Just went and cleared all codes. take car for a quick drive using Sat Nav (that didn't work to well) and these are the fault codes I have now!
    Andy idea's? Could it be a faulty DVD or DVD Drive?
    Saturday,28,January,2012,19:18:52:23493
    65 67 73 75 76 77
    Coding: 0011584
    Readiness: 0000 1001
    Coding: 0000001
    Coding: 0004872
    Coding: 00100
    Shop #: WSC 00672
    Coding: 20001
    Shop #: WSC 00672
    Coding: 0071114
    Coding: 02111
    Shop #: WSC 00672
    Coding: 0006411
    Coding: 0433157
    2 Faults Found:
    02261 - Data Medium
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 5
    Fault Frequency: 9
    Reset counter: 154
    Time Indication: 0
    Date: 2012.01.28
    Time: 18:38:44
    Freeze Frame:
    Mileage: 655350 km
    Count: 2801
    Clock: 19:00
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 114
    Time Indication: 0
    Date: 2012.01.28
    Time: 18:33:56
    Freeze Frame:
    Coding: 00001
    Shop #: WSC 00000
    Coding: 07855
    Shop #: WSC 00672
    Coding: 0433157
    2 Faults Found:
    02261 - Data Medium
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 9
    Reset counter: 154
    Time Indication: 0
    Date: 2012.01.28
    Time: 18:38:44
    Freeze Frame:
    Mileage: 655350 km
    Count: 2801
    Clock: 19:00
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 114
    Time Indication: 0
    Date: 2012.01.28
    Time: 18:33:56
    Freeze Frame:
    Coding: 0001024
    18,288
    Post Thanks / Like
    Show pic of the front of the actual unit.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    Nov 2011
    SE London/Kent
    29
    Post Thanks / Like
    Hi Nigel,
    As below. This is the newer LED model I understand!
    Thanks Andy
    Nov 2011
    SE London/Kent
    29
    Post Thanks / Like
    Chaps,
    All sorted now thanks. Contacted ebay seller explaining I had a problem with the unit. He came to my house with a new unit and all working fine now.
    Thanks,
    Andy
    18,288
    Post Thanks / Like
    They have basically converted an 8P0 193 nav unit to an A4 8E verion with fascia changes, but whats very interesting is audi show a 193 unit now, unrelated to yours as the log clearly shows the 8P version as part number.
  8. Thanks Amason007 thanked for this post
  1. RNSE Install Antenna Question
    By MattyW19 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th December 2011, 19:17
  2. Speaker/indicator buzz - RNSE/SDS install
    By Nickl in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th June 2010, 12:24
  3. How much to install BT - RNS-E
    By Niknak in forum In-Car Entertainment
    Last Post: 6th February 2008, 19:23
  4. RNS-E Install Done....
    By cliveywolves in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th January 2007, 12:49
  5. RNS-E install
    By beerglass in forum In-Car Entertainment
    Last Post: 22nd June 2006, 12:22
