Sky InsuranceRevo Technik
Results 1 to 10 of 10
    Dec 2006
    42
    Post Thanks / Like
    Checking a RNS-E mk2 is actually a RNS-E mk2
    Hi everyone.
    Just bought a RNS-E Mk2 to swap for the Mk1 in my '56 A3 Sportback. I just wanted to check that this Mk2 is actually a Mk2! Forgive me, this is the first Audi I've owned and not exactly clued up on all the difference.
    From what I can work out, it would be a Mk2 because:
    • It has a Media button
    • It has a glossy surround
    • It has the high-resolution screen
    • It has the part number 8P0 035 193 G
    Is there anything else I should be looking out for?
    Thanks in advance.
    Paullie's Avatar
    Banana Menace!
    Jan 2011
    Aberdeenshire
    2,011
    Post Thanks / Like
    Hi there, if it has all of the things you mention above, then it is definitely a MK2 RNS-E and with the glossy black screen surround it is the 2011 version (8P0 035 193G) as opposed to the 2010 (8P0 035 193B), which has the matt surround. The MK1 RNS-E (8P0 035 192*) has a CD/TV button and it doesn't have chrome knobs. HTH x
    MY10 S3 8P3 S-TRONIC, IMOLA YELLOW
    SHARK PERFORMANCE STAGE 2
    gary3306's Avatar
    Oct 2010
    Northumberland
    839
    Post Thanks / Like
    Also the Mk2 uses SDHC cards up to 32gb each whereas the mk1 will only entertain sd cards (NOT HD) at 4gb max (I think) each.
    Suzuki GSX-R 750 K6
    A4 S-Line. Mods so far; Cruise, DIS, Mk2 RNS-e, Audi 6 CD changer, XcarLink with self manufactured permanent ipod dock, B8 MFSW, Dectane Dayline Headlights with independantly switched DRL's, RS4 Rear ARB, De-badged, RS4 pedals, HIDS, RS4 front grille and RS4 style fog surrounds, LCR splitter in Satin Black, Rear Park Assist, LED gearknob, Red footwell lighting, Kitchen sink and Shower cubicle.
    Dec 2006
    42
    Post Thanks / Like
    Thank you for your replies. Would there be any issue with a 2011 model going in to a 2006 car that already has RNS-E Mk1? Also is there any difference, apart from the gloss/matt, between a 2010 and a 2011?
    Paullie's Avatar
    Banana Menace!
    Jan 2011
    Aberdeenshire
    2,011
    Post Thanks / Like
    There would be no issues at all with fitting a MK2 RNS-E to an older car that already has the MK1 RNS-E fitted. It may need some coding, depending on if you have bluetooth, BOSE, multifunction steering wheel etc, ..but everything can be done via VCDS, with no additional wiring required. You're spot on with the 2010 and 2011 difference, ..only the glossy screen surround. I had a non glossy MK2 and swapped it over for a glossy one a month or 2 ago. Very simple job to swap over and code, took me 15 minutes at the most. The hardest part is getting the actual unit out of the dash, lol, but with the correct removal keys and a bit of pulling them outwards from the unit all at the same time, it will eventually come out. Paula x
    Dec 2006
    42
    Post Thanks / Like
    Thank you Paula. Forgive my ignorance, but what is VCDS and how easy is it to code? We pick the car up on Saturday and it already has bluetooth but not Bose or the multi function steering wheel.
    bez101's Avatar
    Jul 2008
    3,425
    Post Thanks / Like
    mine has the cd/tv button and black knobs but its a mk2
    s8craig's Avatar
    Jul 2005
    Manchester
    1,104
    Post Thanks / Like
    You probably have a modded one, I have several A4 units with black knobs and CD/TV buttons, but they are media units.
    My Retrofit Website
    http://www.tclsatnav.com
    bez101's Avatar
    Jul 2008
    3,425
    Post Thanks / Like
    i have that many get nicked around here thought it would be safer
    Dec 2006
    42
    Post Thanks / Like
    Just to say Mk2 unit picked up and it's very good. Next stop, finding an AMI for not very much money.
  1. RNS-E mk1 vs mk2 ?
    By its_neil in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th December 2011, 06:46
  2. Aux in RNS-E mk2?
    By moag in forum In-Car Entertainment
    Last Post: 1st July 2011, 00:23
  3. RNS-E Mk2 Instruction Manual
    By royjk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd June 2011, 12:15
  4. 32GB SD Card for RNS-E MK2
    By Agent_Trig in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st April 2011, 11:39
  5. Mk2 TT RNS
    By N8 in forum TT/TT-S/TT-RS Forum
    Last Post: 1st July 2010, 11:56
