Adrian S FluxW8 Performance
Results 1 to 8 of 8
    Dec 2010
    Littleborough
    88
    Post Thanks / Like
    RNS-E mk2 Coding Issues - Help Please!
    Hi Guys,
    I'm trying to retrofit the RNS-E mk2 into my A3 Black Edition that has the following kit (originally had Concert radio)
    • MFSW
    • BOSE
    • BLUETOOTH + MOUNTING PLATE INSIDE ARM REST
    • IPOD CONNECTION IN GLOVEBOX
    I have read that I need to change the BOSE pin first which I have done B5 to B7, the old Grey B7 wire from the AUX is now taped up.
    Do I need to remove othe two AUX pins and disable in VCDS somewhere?
    The unit is installed and working but I must have the coding wrong.
    Original coding was -
    Navigation: 0209755
    Telephone: 0001222
    I have changed the Navigation coding to 0209715 Is this correct?
    What would I change the Telephone code to ....................?
    Also in the CAN Gateway I have ticked the Navigation button, do I need to untick Radio?
    VCDS report below
    Many Thanks
    Chassis Type: 1K0
    Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 55 56 62 72 77
    VIN: XXXXXXXXXXXXXXXXXXXXX Mileage: 58200km/36163miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 1010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: Malfunction 0010
    Address 01: Engine (CBB) Labels: 03L-906-022-CBA.clb
    Part No SW: 03L 906 022 FD HW: 03L 906 022 BQ
    Component: R4 2,0L EDC G000SG 3613
    Revision: 13H01--- Serial number: AUX7Z0I1FN20AF
    Coding: 0000072
    Shop #: WSC 84224 681 674150
    VCID: 6CD25115361B
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
    Component: ESP MK60EC1 H35 0106
    Revision: 00H35001
    Coding: 16426012092300FB681106E4902000823800
    Shop #: WSC 06314 000 00000
    VCID: 74E249756E2B
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 BH HW: 8P0 820 043 BH
    Component: KlimavollautomatH09 0100
    Revision: 000905 Serial number: 8P0820043BH
    Shop #: WSC 00000 000 00000
    VCID: 73E04A696B25
    Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
    Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
    Component: Bordnetz-SG H54 2801
    Revision: 00H54000 Serial number: 00000009361019
    Coding: 118A0F81B0141380EF00000A0000000000084E056406040364 2000000000
    Shop #: WSC 06314 000 08192
    VCID: 489ACD854223
    Part No: 8P2 955 119 F
    Component: Wischer AU350 H10 0040
    Coding: 00056595
    Shop #: WSC 06314
    Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X1.clb
    Part No SW: 8P0 919 475 F HW: 8P0 919 475
    Component: PARKHILFE 4K H06 0102
    Revision: 11001001 Serial number: 52340902803835
    Coding: 000003
    VCID: 418CD0A16119
    Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
    Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
    Component: Airbag AU1042 H06 0090
    Revision: -------- Serial number: 003CA004WJZT
    Coding: 303142383038303030374A55305238503053
    ASAM Dataset: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4.rod
    VCID: 499CC8815929
    Driver's Airbag Crash Sensor:
    Serial number: 3572DRB40000832932DQ
    Passenger Side Airbag Crash Sensor:
    Serial number: 3582DRB40000831C92CY
    Driver's Rear Airbag Crash Sensor:
    Serial number: 35128RB4000049835ECU
    Passenger's Rear Airbag Crash Sensor:
    Serial number: 35228RB400004ACD8D92
    Driver's Front Airbag Crash Sensor:
    Serial number: 35547RB400004AC4D2E$
    Passenger's Front Airbag Crash Sensor:
    Serial number: 35647RB400004AC455BW
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0004042
    VCID: 418CD0A16119
    Part No: XXXXXXXXXXX
    Component: E0221 H06 0030
    1 Fault Found:
    01304 - Radio
    004 - No Signal/Communication - Intermittent
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 982 C HW: 8P0 920 982 C
    Component: KOMBIINSTR. VDO H19 0860
    Revision: D0H19007 Serial number: 2241I007016167
    Coding: 0004428
    Shop #: WSC 00444 210 81309
    VCID: 397CB84109C9
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 S HW: 1K0 907 951
    Component: J533__Gateway H16 0210
    Revision: H16 Serial number: 3400K092030662
    Coding: E9A17F06400602002103
    VCID: 3778BE793FDD
    2 Faults Found:
    01304 - Radio
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 136
    Mileage: 58185 km
    Time Indication: 0
    Date: 2011.08.25
    Time: 17:40:16
    01044 - Control Module Incorrectly Coded
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 1
    Fault Frequency: 2
    Reset counter: 136
    Mileage: 58191 km
    Time Indication: 0
    Date: 2011.08.25
    Time: 19:04:31
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H19007 Serial number: AUX7Z0I1FN20AF
    VCID: 397CB84109C9
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
    Component: RNS-E PU EU H05 0200
    Revision: 0000011S Serial number: AUZBZ7KD203200
    Coding: 0205715
    Shop #: WSC 00141 211 17933
    VCID: 346289752EAB
    9 Faults Found:
    00862 - Antenna for GPS Navigation (R50/R52)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 136
    Freeze Frame:
    Mileage: 58200 km
    Count: 2608
    Clock: 17:09
    02261 - Data Medium
    014 - Defective
    Freeze Frame:
    Fault Status: 01101110
    Fault Priority: 5
    Fault Frequency: 9
    Reset counter: 96
    Mileage: 58191 km
    Time Indication: 0
    Date: 2011.08.25
    Time: 19:45:27
    Freeze Frame:
    Mileage: 58200 km
    Count: 2608
    Clock: 17:18
    00856 - Radio Antenna
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 136
    Freeze Frame:
    Mileage: 58190 km
    Count: 2508
    Clock: 19:04
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 96
    Mileage: 58191 km
    Time Indication: 0
    Date: 2011.08.25
    Time: 19:04:53
    Freeze Frame:
    Mileage: 58190 km
    Count: 2508
    Clock: 19:04
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 136
    Freeze Frame:
    Mileage: 58190 km
    Count: 2508
    Clock: 19:04
    00878 - Connection to Speaker Front Left
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01111011
    Fault Priority: 5
    Fault Frequency: 4
    Reset counter: 191
    00879 - Connection to Speaker Front Right
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 191
    01305 - Databus for Infotainment
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 254
    Reset counter: 136
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 96
    Mileage: 58203 km
    Time Indication: 0
    Date: 2011.08.26
    Time: 16:52:04
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
    Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
    Component: Tuer-SG H03 0060
    Coding: 0000692
    VCID: 4380DAA97B05
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 E
    Component: EPS_ZFLS Kl. 233 2501
    Revision: 00H15000
    Shop #: WSC 02069 000 90108
    VCID: 2C529115F69B
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 J
    Component: KSG H11 0080
    Coding: 1980200002186D0985054C9FC637
    VCID: 4380DAA97B05
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
    Coding: 0000692
    VCID: 4482D9B57E0B
    Address 55: Xenon Range Labels: 8P0-907-357.lbl
    Part No: 8P3 907 357
    Component: Dynamische LWR H01 0010
    Revision: 00000001 Serial number:
    Coding: 0000013
    VCID: FAFEE74DCC4F
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0205715
    VCID: 346289752EAB
    9 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 136
    Freeze Frame:
    Mileage: 58200 km
    Count: 2608
    Clock: 17:09
    02261 - Data Medium
    014 - Defective
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 9
    Reset counter: 96
    Mileage: 58191 km
    Time Indication: 0
    Date: 2011.08.25
    Time: 19:45:27
    Freeze Frame:
    Mileage: 58200 km
    Count: 2608
    Clock: 17:18
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 136
    Freeze Frame:
    Mileage: 58190 km
    Count: 2508
    Clock: 19:04
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 96
    Mileage: 58191 km
    Time Indication: 0
    Date: 2011.08.25
    Time: 19:04:53
    Freeze Frame:
    Mileage: 58190 km
    Count: 2508
    Clock: 19:04
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 136
    Freeze Frame:
    Mileage: 58190 km
    Count: 2508
    Clock: 19:04
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 4
    Reset counter: 191
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 191
    Freeze Frame:
    Fault Priority: 5
    Reset counter: 136
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 96
    Mileage: 58203 km
    Time Indication: 0
    Date: 2011.08.26
    Time: 16:52:04
    Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
    Component: Tuer-SG H04 0040
    Coding: 0000144
    Shop #: WSC 06314 000 1012544
    VCID: 418CD0A16119
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
    Coding: 0000144
    VCID: 428EDFAD641F
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P0 862 335 S HW: 8P0 862 335 S
    Component: FSE_256x BT H34 0550
    Revision: 00000000 Serial number: 00000005066059
    Coding: 0001222
    VCID: 4686C3BD4837
    1 Fault Found:
    01304 - Radio
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 3
    Reset counter: 136
    Mileage: 58185 km
    Time Indication: 0
    Date: 2011.08.25
    Time: 17:49:25
    warren_S3's Avatar
    Oct 2007
    Undetermined
    4,404
    Post Thanks / Like
    0209707?
    List of codes
    {Instrument Cluster}
    Control Module Coding
    Select 56 (Radio System) Coding -> Function 07
    0?xxxxx: Model
    1 - Lamborghini
    2 - Audi A3 (8P)
    3 - Audi A4 (8E - from MY 2004)
    4 - Audi A4 Cabriolet (8E - from MY 2004)
    5 - Audi A6 (4B)
    6 - Audi TT (8J)
    0x?xxxx: Malfunction Diagnosis
    0 - Malfunction diagnosis for front loudspeakers active
    1 - Malfunction diagnosis for front loudspeakers inactive
    0xx?xxx: Sound Characteristic
    0 - linear Sound Characteristic
    1 - Audi A4 (8E - from MY 2004)
    2 - Audi A6 (4B)
    3 - Audi A4 Cabriolet (8E - from MY 2004)
    4 - Audi TT (8J)
    5 - Audi A3 (8P)
    9 - Sound System
    0xxx?xx: Telephone/Telematic
    1 - No Telephone (Remote Feed Voltage for Microphone active)
    2 - Base plate (Temic - Remote Feed Voltage for Microphone inactive)
    3 - Base plate (Cullmann - Remote Feed Voltage for Microphone inactive)
    4 - Base plate (Nokia - Remote Feed Voltage for Microphone inactive)
    5 - Telematic Europa (Remote Feed Voltage for Microphone inactive)
    6 - Telematic US (Remote Feed Voltage for Microphone inactive)
    7 - Base plate diagnostic capable with comfort control
    0xxxx?x: Equipment I
    1 - No additional Tuner
    2 - Digital-Radio
    3 - Satellite-Radio
    4 - Satellite- and Digital-Radio installed
    0xxxxx?: Equipment II
    1 - No TV-Tuner, CD-Changer or Multi-Function Steering Wheel
    2 - TV-Tuner installed
    3 - CD-Changer installed
    4 - TV-Tuner and CD-Changer installed
    5 - Multi-Function Steering Wheel installed
    6 - TV-Tuner and Multi-Function Steering Wheel installed
    7 - CD-Changer and Multi-Function Steering Wheel installed
    8 - TV-Tuner, CD-Changer and Multi-Function Steering Wheel installed
  4. Thanks Avus Sportback thanked for this post
  5. #3
    s8craig's Avatar
    Jul 2005
    Manchester
    1,104
    Post Thanks / Like
    RNS-E 0209717 as you've not connected the AUX pins, you can disable the option hence the 1.
    If you decide to wire up the aux then its 0209757
    Tel 0011422
    Enable the navigation option in the can gateway, clear all your error codes and that's it really
    My Retrofit Website
    http://www.tclsatnav.com
  6. Thanks Avus Sportback thanked for this post
  7. #4
    Dec 2010
    Littleborough
    88
    Post Thanks / Like
    Thanks for the info, would it be xxxxxx7 as I don't have a cd changer that why I thought it may be xxxxxx5 ?
    Just realised I missed the xxx9xxx for the Bose I presume, I selected xxx5xxx for the A3 8P doh!, thought it didn't sound right.
    Will re-code in the morning
  8. #5
    warren_S3's Avatar
    Oct 2007
    Undetermined
    4,404
    Post Thanks / Like
    iPod acts as CD changer - basically 5 playlists and the sixth is the library, hence the final 7
  9. Thanks Avus Sportback thanked for this post
  10. #6
    Dec 2010
    Littleborough
    88
    Post Thanks / Like
    Thanks Warren
  11. #7
    Dec 2010
    Littleborough
    88
    Post Thanks / Like
    I have now cleared all fault codes except for the two Antenna codes which I know I'm unable to clear without the Antenna mod.
    I have also bought an AMI interface and got a loom from Kufatec, do I need to code this also?
  12. #8
    s8craig's Avatar
    Jul 2005
    Manchester
    1,104
    Post Thanks / Like
    Yep, if your fitting AMI the code should be 0209725 assuming that you are going to lose the Ipod interface
    Also you need to enable Media Player 3 (I think) in the can gateway, but if you do a scan of the can gateway it will tell you which mediplayer is not registered. It's 2 or 3 but I think it's 3.
    My Retrofit Website
