W8 PerformanceVAG Check
    May 2011
    wales
    74
    Post Thanks / Like
    RNS-E SATNAV USER HELP.
    Anyone care to have a bash at my problem,
    I noticed while travelling to manchester a couple of weeks ago, and travelling up the A49 from south wales, that the satnav would direct me into towns, when clearly the A49 had a bypass, this happened on nearly every big town untill i abandoned the satnav route for good old honest map reading via the wife.
    Just yesterday i was travelling near my home to monmouth, which involved about 15 miles of farm lanes, now i know monmouth from my house is mostly A-roads, dual carriageways and motorways, i only used the nav to show a freind.
    I have an uptodate satnav disc 2011, and i must have changed a setting without knowing, i have tried changing a few settings, but get more confused the more i look at it, shortest, longest, quickest.
    So a big thanks to anyone who may point me in the right direction, by the way i did northern france to southern france without a problem last year, the last time i really used it, 2007 disc.
    thanks john
    s8craig's Avatar
    Jul 2005
    Manchester
    1,104
    Post Thanks / Like
    Have you got the route criteria set to shortest and not fastest? I inadvertently set mine to shortest and it took me all over the place until I put it right.
    My Retrofit Website
    http://www.tclsatnav.com
    May 2011
    wales
    74
    Post Thanks / Like
    Hi thanks s8craig,
    I thought by putting in the shortest, it would take me up farm lanes as opposed to using the a-roads motorways etc, if the route was shorter, i always thought faster would use all the main highways, perhaps the mistake i,m making, anyway thanks again, i,ll give it a try on the weekend.
    john
    s8craig's Avatar
    Jul 2005
    Manchester
    1,104
    Post Thanks / Like
    I always use fastest and it usually does the trick, as I said shortest took me through town center and even cost me £60 in congestion charges when I was down south as it took me through London city center instead of around the M25 which would have been quicker and used less fuel.
    My Retrofit Website
  6. Thanks johnmandy thanked for this post
  7. #5
    May 2011
    wales
    74
    Post Thanks / Like
    Quote Originally Posted by s8craig View Post
    Thanks s8craig, i mis-understood your reply i,ll change my setting to fastest, that should do it,
    my heads fried tonight,
    john
