VAG CheckBadger5
    dusty's Avatar
    Nov 2010
    nw england
    55
    Post Thanks / Like
    Help with RNS-D conversion
    hi, i have a 2001 s3 with single din bose stereo, i have just bought an RNS-D sat nav from a 2002 8l s3 with code, is the conversion pretty straight forward or would i be better getting someone to do it for me, what else will i need to fit the RNS-D to my car, i am aware i will have to move my climate control unit and trim the sides down to fit lower down in the dash, i will also need a double din cage, what else will i need, should i already have the wiring loom in my car or will i need an extra loom, any help would be appreciated thanks
    2001 s3, stage 1 amk, nogaro blue, lowered 30mm, forge adjustable tie bars, Awesome heavy duty clutch, 18" nouvalari alloys, ambient lighting, tt pedals, led side lights, led number plate lights, abt number plate surrounds, simota carbon induction, resonated milltek cat back exhaust, bailey dv,
    s8craig's Avatar
    Jul 2005
    Manchester
    1,104
    Post Thanks / Like
    Have you got a TMC module and wiring loom, it will not talk to the cluster without a TMC module.
    My Retrofit Website
    http://www.tclsatnav.com
    dusty's Avatar
    Nov 2010
    nw england
    55
    Post Thanks / Like
    all i have got is the unit and the code no wiring
