JuicyDTUK
    Jul 2011
    11
    Post Thanks / Like
    Newbie to Navigation Plus (Firmware and Mp3 query)
    Hi all,
    I have had my Audi S3 2007-2008 for a week now (love the car!) but im a bit dissapointed with the Navigation Plus system. The CD-Changer doesnt seem to play mp3s, when inserting a disc, the MMI displays "Unreadable Format"
    I know this question has been asked numerous times, but each answer seems to be different.
    I currently have the following version on my Navigation Plus System
    S/W 0650
    HW H74
    Map 8P0919884_AA_EUW
    Would I be able to upgrade the firmeware of my device? would this resolve the above problems? and also give me 3D maps? what is the latest offical release version?
    Also, would upgrading the firmware break the communications to the DIS? or would it work normally?
    Paullie's Avatar
    Banana Menace!
    Jan 2011
    Aberdeenshire
    2,011
    Post Thanks / Like
    I'm not too knowledgeable on these things, buddy, but welcome to the forum! My RNS-E is the MK2 which is fitted to MY10 onwards A3/S3's and paired with the CD changer I have fitted, it doesn't play MP3's either . I just download all the MP3's I want to play onto SD cards and use these instead. Again I believe 3D maps are only available on the later MK2 systems, but Nigel (NHN) is the person who knows all there is to know about Audi electrics and ICE related stuff, so hopefully he will be able to help you out.
    MY10 S3 8P3 S-TRONIC, IMOLA YELLOW
    SHARK PERFORMANCE STAGE 2
    s8craig's Avatar
    Jul 2005
    Manchester
    1,104
    Post Thanks / Like
    You should have 3D view anyways, go into Navigation settings and map type and the option should be 3D or birds eye view.
    No you cannot upgrade any higher than 0650 for any extra functionality and 650 is the highest firmware, well 660 if you include hacked units for SDS, but that would require some rewiring as well.
    The CD changer interface has not changed for 10 years, still the same as the 2001 cars they first appeared in with no text support or mp3.
    My Retrofit Website
    http://www.tclsatnav.com
    Jul 2011
    11
    Post Thanks / Like
    Thanks for the replies
    I will go through the options of the unit, do any SD cards work OK with the MMI for me to be able to play Mp3s?
    s8craig's Avatar
    Jul 2005
    Manchester
    1,104
    Post Thanks / Like
    Upto 4GB SD cards, non SDHC with a limit of 511 tracks/folders per card, so basically 1000 tracks between them.
    My Retrofit Website
