JBSKowalski
Results 1 to 9 of 9
    Lancaster
    1,145
    Post Thanks / Like
    Bluetooth added - Working but a few issues.
    I hope someone can offer some advice on this.
    I've installed the bluetooth on my car, I have a RNS-E with the latest software installed.
    The satnav sees the bluetooth, i can make calls and it's all fine.
    I have a few issues though, I have a MFSW and when I press the left button to scroll through the numbers, it's on a limited time. After about 3 seconds of scrolling it goes off.
    Also, I cannot enter 77 on vcds. It says no controller installed. Any advice welcome.
    No fault codes showing on the rns-e either.
    To do: None yet.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,104
    Post Thanks / Like
    If you cannot enter module 77 on an A4 it is because your K-line is not connected correctly or you have not installed a genuine Audi unit.
    My Retrofit Website
    http://www.tclsatnav.com
    Lancaster
    1,145
    Post Thanks / Like
    If Kline wasn't connected properly, would it work right?
    To do: None yet.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,104
    Post Thanks / Like
    Yes it would work, k-line is just for diagnosis.
    My Retrofit Website
    Lancaster
    1,145
    Post Thanks / Like
    Excellent, I'll go out and double check it all.
    Cheers Craig.
    To do: None yet.
    Lancaster
    1,145
    Post Thanks / Like
    Turned out I had the Kline on the wrong wire. Oops!
    So I can log into it now.
    All is fine, but the time it gives you to scroll through the numbers is still really low.
    To do: None yet.
    Lancaster
    1,145
    Post Thanks / Like
    Any ideas on this ladies and gents? I'm sure it's just a coding issue somewhere.
    To do: None yet.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,104
    Post Thanks / Like
    There is no coding for that
    The BT module should be 0011822 for an A4 with RNS-E and MFSW
    The RNS-E should be 00xxx7xx
    The cluster adaptation channel 62 should be 23
    The steerring wheel should be 04xxx
    My Retrofit Website
    Lancaster
    1,145
    Post Thanks / Like
    hmm, seems right then Craig. Oddness!
    To do: None yet.
