KowalskiBadger5
    Apr 2010
    529
    Post Thanks / Like
    RNS-E Problems - Disk Drive Load/Eject Malfunction
    Hi Guys,
    Recently fitted an RNS-E as well as an OEM Bluetooth unit, all was well until i tried to use the sat nav (disc was sent after the unit so was testing that)
    Basically, the unit isn't loading or ejecting any dvds/cds. originally thought it was the the load/eject settings on channel 67, it is however set to 0 so should work fine. if only it was that though!
    So this is the fault...
    02444 - Disk Drive Load / Eject Malfunction
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 241
    Time Indication: 0
    Date: 2011.04.04
    Time: 20:54:32
    Do I need a new drive? Anyway to fix this?
    Thanks in advance, Carl
    kite's Avatar
    Oct 2007
    East Berks
    470
    Post Thanks / Like
    Try a CD lens cleaner.
    I have seen a post somewhere that included pix of a laser change... might be worth a google
    A4 (b6) 2.5 TDi QS Saloon.
    Apr 2010
    529
    Post Thanks / Like
    problem is, the drive isn't loading/pulling the disc into the unit?
    kite's Avatar
    Oct 2007
    East Berks
    470
    Post Thanks / Like
    Quote Originally Posted by C17LJR View Post
    Rosstech wiki shows a reset
    Channel 111: Reset
    • To perform a system reset/restart save 1 as new value.
    kite's Avatar
    Oct 2007
    East Berks
    470
    Post Thanks / Like
    if you decide to replace, this thread might help
    RNS-e Laser replacement instructions - VW AUDI Forum - VWAF
    Jul 2010
    Post Thanks / Like
    I recently had the same problem, took the unit out of the car, took the top plate off and found that my disc had got stuck above the drive mechanism once i removed from the back and then tinkered with it pushing it back in as i was hitting the eject button it went in and under with no problems, just need a new disc as mine was badly scratched!
