AWEsome GTIRevo Technik
    S4 Cabriolet 04
    Jul 2009
    Bradford, England
    26
    Post Thanks / Like
    my sat nav says i am somewhere else?
    i have an audi s4 cab 04 model with rnse, no problems with this until recently it says i am elsewhere on the map usually miles away. i took the disk out yesterday for a bit and it worked fine until the same problems occured again today. do i need a new antenna? any help would be appreciated.
    S4 Cabriolet 04
    Jul 2009
    Bradford, England
    26
    Post Thanks / Like
    i have purchased a new gps antenna i think its the lead that goes through the hinge in the boot which is faulty, this seems to be a common fault on audi cabs, once i get the new lead i will install it in the instrument cluster and will post on here just so someone gets an answer if they have a similar problem. i cant be bothered trying to repair the wire in the hinge.
