Badger5Forge Motorsport
Results 1 to 9 of 9
    Tankman's Avatar
    Dec 2006
    41
    Post Thanks / Like
    iPhone 4 with RNS non-display of Directory
    Is it possible to make this version show directory of iPhone 4 in DIS via Bluetooth.
    The Nokia 6230 works fine, but only via reading the sim card through the hands free kit fitted in the armrest. So, is there a workaround?
    18,288
    Post Thanks / Like
    Check the coding mate on the car.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    Tankman's Avatar
    Dec 2006
    41
    Post Thanks / Like
    Excuse the ignorance this end, how do I check the coding?
    s8craig's Avatar
    Jul 2005
    Manchester
    1,104
    Post Thanks / Like
    What car is it?
    How old is the car?
    Is everything factory fitted or retrofit?
    My Retrofit Website
    http://www.tclsatnav.com
    Tankman's Avatar
    Dec 2006
    41
    Post Thanks / Like
    2005 B7 A4 3.0TDi S-line Quattro Auto. As far as I know, this is a factory installation. It has the full phone preparation in the armrest and Bluetooth connectivity.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,104
    Post Thanks / Like
    Sounds to me like the BT module is too old, the wrong type (D or E revision) or possibly a coding issue.
    My Retrofit Website
    Jan 2004
    York
    1,639
    Post Thanks / Like
    If it's factory fit you'll have colour dis and a shark fin...... Second what s8craig says. Older Audi BT modules don't fully support the later iphones.
    Going ..... '56 Audi A4 2.0 TFSI Sline SE quattro Avant
    To be replaced by a
    11 plate SEAT Exeo CR ST Sport Tech
    18,288
    Post Thanks / Like
    Quote Originally Posted by Tankman View Post
    You'll need a tool like vagcom/vcds to log into the car & the BT module to check what it has been programmed for, you can ask a kind member to do this by clicking the vcds members list link in my sig or buy vcds to do yourself, the latter is more expensive btw & I do sell these.
    It may also be as already stated, older module, only 1 real logical way to find out mate.
    Tankman's Avatar
    Dec 2006
    41
    Post Thanks / Like
    OK thanks for the info. I bought VCDS already but haven't used it yet as I am not a techie and it scares me a bit. I only bought it because the Xenons on my car do not adjust for continental driving from the RNS menu.
    Looking at the DIS, does green red and white count as colour? No sharkfin, so it looks like I have a ******* of a car that doesn't want to play. Another thing, there are two recorded phone contacts on the system which I cannot delete.
    Thank you for all your help so far.
