KowalskiDPM
    Aug 2007
    292
    Post Thanks / Like
    Need Help with RNS-E 2010 coding
    Hi Guys,
    Wondering if you could help. My A3 currently has the RNSE in it. I recently bought a new 2010 version of this.
    I thought it was a straight swap but clearly not.
    Can someone tell me if coding this is not to difficult?
    The current setup has
    Multifunction Steering wheel
    SDS High
    I have vagcom but not too sure what i should be doing.
    thanks
    Apr 2009
    Shirley, Solihull
    542
    Post Thanks / Like
    put the old one back in and then check the coding in 57-sat nav and make a note of them then install your new one and change the coding accordingly...
    Available soon in the For Sale Section.....
    RS4 Pedals - Drivers side mirror mounting/wiring
    B6 Cab Front Grills - Drivers side B6 Cab Headlamp
    Moro Blue Mirror Caps - Full set of Cab Windscreen Surrounds
    Symphony 6 disc Head - Unit Full set of B6 Cab Manuals inc Leather Wallet
    N/S B6 Rear Lamp - RS6 Auto Brake Pedal
    PM for more details.......
    DeckedS3's Avatar
    Apr 2008
    South East
    467
    Post Thanks / Like
    Where did you buy the 2010 RNS-E from?
    Meteor S3, REVO Stage 2+, APR HPFP, Milltek TBE, Sach's Clutch, Bilstein PSS10's, EVOM's CAI, Forge TB & DV with Pro-Alloy IC, BBS CK 19" My S3
