GNJRevo Technik
Thread: help with rsne
    Dec 2008
    Sheffield England
    Post Thanks / Like
    help with rsne
    Hi could someone please inform me where i am going wrong i am running vcds 10.6 ive removed symphony from 2007 A4 cab and fitted rsne 8E0 035 192K most works fine except my vcds will not connect to radio or nav to code it in. I need to code the DIS. The symphony had quadlock conector as the rsne, does the K wire want moving thanks
    882
    Post Thanks / Like
    Edit - just re-read the post if you have symphony 3 then you will need to move the k-line wire from pin 7 on the c-connector to pin 5 on the b connector. If you have Bose then there will already be a wire in pin 5 which will need to be move to pin 7 on the same connector.
