UnicornJBS
    Jun 2004
    Post Thanks / Like
    S2 Avant front driveshafts
    Hi all,
    I`ve have to change the "cv" boots on the front driveshafts, and have been told that once the hubs and driveshafts are separated the "cv" itself can be hit with a mash hammer to get them off the shaft. I have am at this stage now but my challenge is that they don`t seem to want to come off.
    Can anyone please help with some info on how they should come off..?
    Thanks !
    36
    Post Thanks / Like
    Re: s2 Avant front driveshafts
    I am sure there is a trick to this where you do not hit it with a hammer but use the bolt to push it off - look on www.s2forum.com - I read it somewhere in there.
    HTH
    Jun 2004
    Post Thanks / Like
    Doug rs2,
    Thanks for your input my friend. I managed to "suss" it by getting the car up in the air it was easier to knock them off.
    Also i just found out about something called a " stretch boot " which will fit over ( with aid from the special cone tool ) any cv joint, saving the need for removal.
    I guess we live and learn .
    Cheers.
    ps, "Europarts" supplied the wrong cv kits too, so i`ll be careful before i use them again.+ They called my car "oddball " damn cheek!
