Sky InsuranceForge Motorsport
    Feb 2004
    Post Thanks / Like
    S2 Overboost Problem
    Hi,
    I have a 1993 S2 6 speed which is awesome but because of a hugely annoying intermittent problem I am at the end of my tether with it. Basically under hard acceleration the car is liable to lose all power for a split second. Once this has happened the first time it will happen again with the slightest boost. If I switch the car off and start up again it may be fine for another few weeks!!! It always seems to happen when I really dont want it to like overtaking a truck on an A road.
    I have tried the following;
    Changed the boost control valve
    Changed the lamda probe
    Changed the MAF meter
    Had the MAF meter wiring block re-wired.
    Tried sweet-talking the car
    None of which have solved it. I have already spent lots on diagnostics and havent even come close. Any ideas would be very much appreciated.
    I am in the UK
    Apr 2004
    Manchester, UK
    Post Thanks / Like
    Re: S2 Overboost Problem
    I have the same problem on my '94 S2 (ABY engine code). However, it's only surfaced twice in 3 years, each time it was in the winter when the whether was pretty cold. Let me know if you manage to solve your problem.
    Mick
