Well guys, I went down to Audi today.
Asked for a quote, as I want my timing Belt done and also a service just for peace of mind.
Ł1500![]()
cars done 34k
Ach well the joys !
Ł1500![]()
cars done 34k
Ach well the joys !
Oh my !!! ... I'm not looking forward to it myself either. I've bought my car a couple of weeks ago, but the service indicator says its due in about 1000 miles or so and its not one of those small Oil change services either.
There have got to be good sensible options. I was advised to use Fontain. I'm not sure as they are Audi specialists but not Audi dealers as such. It'll probably affect the resale price of my RS6 if I did use a non Audi dealer to service my car too? Pity really, as I know some really GOOD service outlets and mechanics.
Not sure yet what is the best thing to do ...
Agreed mate, ive had some hi tech cars, and trust me if you dont have main dealer on an Rs6 you will have real worries selling it again.
And the complete truth is some of the small independent mechanics are FAR better !!
I must agree..you need the dealer stamos but fontian is well known and can also carry out warranty work on Audis now.!
Mine has done 34k so cambelt due Feb next year..but I will do it myself and borrow the tools off my mate at Audi..no way letting anyone else work on this car.....!!!! no way.
I have extended warranty so need the services to be done at the dealer, BUT with block execption they can't preasure you into only using Audi main dealers..as long as you use Audi OEM parts with a reciept it is ok to service anywhere you want even with a brand new car
Audi RS6 Daytona GreyLoving all 455.7BHP of her
I see you are in Scotland mate - have you got a quote for the work from Ingram Audi in Ayr?Originally Posted by bbigman2000
I use them, and they are generally 35% ish less than the service costs at the usual franchise stealers (Glasgow/Stirling/Edinburgh Audi). Ingram no longer have the franchise to sell new Audis, but the workshop and mechanics are still Audi approved, you get an Audi stamp in the book, and the warranty is still honoured.
They've done a decent job for me on the last couple of visits (due a service tomorrow in fact!).
Worth a go???
987 Boxster 2.7 (05) - Current
A3 2.0T Quattro S-Line (55) - gone
S3 Quattro (02) - gone
Thanks mate appreciated, Im just a bit far away though, Im up near Aberdeen so it would be a hell of a run.
Im going to use Audi Hawco in Elgin, Ive been asking about and so far nothing but good has been said about them.
I was luck with mine, it has been done, the next one will be in about 3 years time as I dont do the miles.. But yer Crawley Audi said it would be about 2K
cheers mate, I think labour in london is £100 per hr plus where as up here im only £60 an hour !
Well guys, ive got my estimate through,
Full service, plugs, air filters, and timing belt total inc vat £1612.52
Not bad ?
Gosh ... myabe it is just me but I'm still taking that in. I'm just thinking, even if it takes them the whole day, say a whole 7 hours to do the service. Thats still Ł420 labour inc (at Ł60/hour you mention). So the parts cost around Ł1200 inc? Maybe I'm looking at this too simplistically.
However, I used to own a BMW 7 series (E38 - still do actually) which I bought when it was fairly new (a couple of years old) and I used get quoted all kinds of full service rates, from Ł800 all the way to Ł2k ! Such variance! (Scotland was always cheaper for me, especially Perth). So what I used to do was get the very basic service done which used to be around Ł300 and get them to mark all the things that needed changing / required work done to it (they do this as part of the service). Then I would buy all the parts that I required from BMW and take it to my mechanic mate to fix. That way I got the stamp I needed, got all the original parts and had all the work done by my mate in front of my eyes!
I wonder whether Audi has a basic charge for servicing? Can't be that high surely!
I hope its not a case of RS6 = expensive car with discerning driver taste = affordability = high service rates = Ł1.5K .... Just thinking aloud ...
Gosh I'm not looking forward to mine !!!![]()
That will equate to 2 days work.Cambelt is about 5 hrs from memory insit they change all the rollers and the water pump..might aswell for what the part cost.
The plugs are £15 aprox and then it takes tons of oil..£1600 is not bad I wouldn't pay that but is ok
996T 48K is 7.9hrs and will cost you £1100 that is with out the belt so I really don't think that is a bad quote.
Audi have got a menu pricing system and the RS is not wacked with a premium if that is what you may have been thinking.
Ask for a menu price print out you should get it this will include book times...the times believe me are in the customers favour as they are warranty times....all times worked out when engine out sort of thing....
Part of the 40K is a cambelt check (40k can be done sooner depending on age) so make sure they have not added abit on for this.
When replacing the air filter ask them to change the airflow meter rings and the rubber stops for the air box...
Mine where worn and when accelerating hard the airbox moved and engine light came on..!!!
VAG-COM to the rescue!! unmetered air delt with it and now ok..2 rubber bungs and airflow meter rings and she is good too go.!
Thank you Marmite, very insightful.![]()
If this helps, I quickly dug out the paper for my last major service which was carried out at 37K, (which was done before the previous oil change service at 42K).
This service was done just over a year ago, here down south.
Breakdown of work done:
Roller (1)
Roller (1)
Belt Damper (1)
Lever (1)
Air Filter (2)
Tensioner (1)
V Belt (1)
Roller (1)
Oil Filter (1)
Brake Pads Front RS6 (1)
Spray Lube (1)
Toothed Belt (1)
Brake Cleaner (1)
V Belt Tensioner (1)
Pollen Filter A6 (1)
Spark Plug (8)
Sump Washer (1)
Anti Freeze (2)
Screenwash Fan (1)
SLX Longlife 2B (8)
PARTS: Ł939.17
Service Carried Out (Ł137.50)
Replaced Front Brake Pads (Ł55.00)
Replaced Cam Belt and Tensioners (Ł275.00)
LABOUR = Ł467.50
TOTAL COST:
PARTS: Ł939.17
LABOUR = Ł467.50
TOTAL = Ł1,406.67 + VAT
GRAND TOTAL = Ł1652.84
Cheap labour rate...!
This looks ok to me really..they are expensive cars to maintain I know my front brakes will need doing soon and that is £900 ish just parts but I knew this when I bought it
thanks lads, I have the break down sitting here for your info
40k service labour £294.15
Replace Auxilliary and timing belt £540.60
Parts :-
roller
relay roll
belt damper
lever
air filter
auxilliary belt
timing belt
spark plugs
cabin filter
fuel filter
oil parts total £537.61
Total 1372.36 + VAT = £1612.53
Marmite, thanks for the info on the air filter replacement, il mention it to them.
Well thats the job done and dusted £1479.40
Highly delighted, she is running awesome.
