    col1892's Avatar
    Nov 2013
    20
    TV upgrade to MMI system
    Hi all.
    I became the proud owner of a 09 RS6 about 6 weeks ago and have tried without success to turn on the TV, turns out my system doesn't have the TV capability installed.
    Audi main dealer cant help, so I thought there may be someone on here with the technical know how to offer me advice.
    Is it just a case of uploading the TV capability into the system, or does it involve changing head units and running cables etc?
    Many thanks in advance for any advice
    NotNormal's Avatar
    Mar 2007
    Lincolnshire
    74
    I'm sure you'll. we'd the additional tuner module plugging in - then activating with vcds
    If you look for a used unit on eBay make sure it's the digital version not the analogue for the obvious reason
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,591
    It is VERY possible, but not cheap as you need new hardware and it's a ball-ache to install.
    a TV tuner (which is about £300 by itself for the 3rd party versions), double that for OEM
    adapter to get the signal into the MMI
    aerials (x2, usually installed under the dash somewhere) - you could get away with one, but need two if you want diversity reception (the ability to maintain a signal and scan for a stronger signal when you're on the move)...
    These guys will do it for you: A6 4F, S6 4F, RS6 4F 2005-2011
    Looks like it is about a grand: Genuine Audi Digital Hybrid TV Tuner Supply & Fit | HappyDayz
    I got a version this kit for my old A4 (2001 B6) and it was about £400 for me to source the hardware (Freeview+ version + other bits) and I think HazzyDayz did it for me for about £550... including several hours labour and coding the software.
    TO be fair, it's about a grand if if get it added as an option when they build it too....
    LostBok/BahnStormer77
    Cockney Boy's Avatar
    Nov 2007
    Aylesbury, Buckinghamshire, UK
    485
    First of all, have you got 2G or 3G? As this will have a bearing on the kit you'll need and there is a cost difference.
    In basic terms the TV tuner will go in the boot and wired into the MOST Loop and Can. Antennas will need to be linked into the rear glass. A bit of coding and your done.
    Tuner, cables antenna modules and a days work is what you'll need.
    Q7 S Line 2010
    MMI 3G
    Adaptive Cruise Control
    Superchip Remap
    Blackvue front and rear accident camera
    BahnStormer
    Feb 2009
    Surrey
    2,591
    Cockney - if he's okay with non-OEM, then there's some pretty simple solutions that can all be done up front: mine had both antennaes on the back of the sun visors and the TV tuner (Ampire DVBT 200) was mounted on the back of the glovebox with the USB ports, TV line in, etc (for iPod video, etc) all accessible direct from there.
  1. Upgrade standard sound system to Bose?
    By woohoo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th April 2009, 18:00
  2. Want to upgrade my sound system!!
    By $clarky$ in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st September 2008, 07:27
  3. fitting ipod adapter for MMI system
    By marka6hunter in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 29th April 2007, 22:09
  4. upgrade a6 avant system........ woodstock + amp and 12"
    By shufti in forum In-Car Entertainment
    Last Post: 20th June 2006, 22:49
  5. Upgrade power locking system
    By 97AUDIA418TQ in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th December 2003, 00:02
