Monster MotorsportVolks Autos
Results 1 to 7 of 7
    Sep 2010
    South Bucks, UK
    17
    Follow bigcw On Twitter
    Adaptive cruise control not working
    Hi all
    Just swapped my trusty A6 Le Mans for an RS6 V10.
    However the adaptive cruise control doesn't want to work. It says 'ACC not available' whenever I hit the button. I know I have to be going over 19mph, but even at motorway speeds it still won't activate.
    The manual says that this error will appear 'if, for example, the brakes are overheated'. Fat chance of that in this weather! I've been scared enough to put my foot down at all let alone give it enough beans to overheat the brakes.
    It also says that 'ACC not available!' (ie the same message but with a ! on the end) means a system malfunction, but my message doesn't have the '!'.
    The only other symptom is that the cruise control light comes up red during the self test at switch on. You know, when all the other lights flash on for a few seconds.
    I'm not sure if it's supposed to flash red or if that indicates a fault. Can anyone with the ACC system confirm?
    Assuming there is a problem, I guess my only option is to take it to Audi for a diagnostic check?
    Cheers, Chris
    My cars, in age order:
    Audi RS6 V10 | MR2 mk2 w/3.0 v6 conversion | 306 Cabrio w/3.0 v6 conversion | 87 XR2 w/2.0 Zetec | 82 XR3 w/1.8 Zetec
    Audi Remapping in Buckinghamshire by GX Tuning
    Jun 2011
    Great Melton Norfolk
    1,340
    Have a look on the vcds users map to see if there is anyone near to you that will scan it .
    Sep 2010
    South Bucks, UK
    17
    I got it scanned at VASS-Tech in Whitchurch today. Apparently it's showing an error of the radar unit heater open circuit or shorted to ground, which proves that there is something wrong with it at least ie it's not just user error!
    Now trying to find a dealership that has the correct tools to deal with it. Apparently it needs a radar alignment 'thing' in order to fix it.
    Chris
    Sep 2010
    South Bucks, UK
    17
    Seems the problem is with the heater in the radar sensor in the front bumper. Audi have ordered the part and the car is booked in on Friday. Fingers crossed that will solve it!
    Chris
    Sep 2010
    South Bucks, UK
    17
    Just in case anyone is interested, the replacement heater unit solved the problem. Replacement was just shy of £250 including the part and labour. They gave me the old one - it looks like it just unclips from the grille so if anyone experiences this in the future it's probably a DIY job to fix other than erasing the fault code.
    Chris
    Jun 2011
    1,340
    Glad its sorted
    Jul 2013
    Quote Originally Posted by bigcw View Post
    Chris
    In my A4 Avant the system's sensor is based on a laser (so is not really a "Radar" that is a "RAdio" Detection And Range). In this case, after the alert "ACC not available" the first thing to do is to clean the lens in front of the car. In my experience (after several mysterious "radar" faults and related repairs) this simply maintenance solve the problem (saving a lot of money).
  1. Cruise control not working!!
    By SL11CKK in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th September 2011, 22:53
  2. Cruise Control not working?
    By JCsS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th November 2009, 17:20
  3. Cruise control not working
    By BILKO1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd November 2009, 16:38
  4. Cruise control not working
    By gidimille in forum General Technical / How To
    Last Post: 7th December 2005, 18:32
