Sky InsuranceAWEsome GTI
Results 1 to 11 of 11
    Post Thanks / Like
    Engine management light on after remap
    Hi
    I wonder if anyone can offer some advise?
    Ive just bought a 2006 rs4 with full non res decat Miltek pipe, Gruppe M induction and a DMS remap. However, the engine management light is on. The previous owner said it came on shortly after the decat pipes and when he spoke to DMS, they said there is nothing you can do. The engine management is telling you there is a problem with the cats.......it hasnt got any!!!!
    Is there anything you can do to get the light off? Would it be worth refitting the original cats? I think it was only done for the noise anyway and I dont suppose it will sound/perform much worse with the cats back on.
    Can you experts help a poor Audi novice out please?
    Ta
    Byzan Pics's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    10,709
    Post Thanks / Like
    A decent tuner should be able to code the rear 02 sensors out. Or you could try using spacers on the rear sensors as that can have an affect too.
    Post Thanks / Like
    Aparantly the guy asked DMS and they said nothing you can do? For a 1250 quid remap I thought that was a bit lame.......
    And I always thought they were the mother of all tunners.......???
    I presume then you would need a custom code? I wouldnt know where to start with that locally?
    Miltek are in Derby where I live. Wonder if they could help? Loads of my friends have decat scoobies and Evo's and no one has the engine management light on?
    Byzan Pics's Avatar
    Apr 2004
    10,709
    Post Thanks / Like
    THE RS4 is a very different animal to the Scoobs/Evos as they do not have after CAT 02 senders.I would ring around, i know many things can be coded out, for instance, i know of a big turbo S3 with a coded out rear 02 sensor for the same reason
    Sep 2007
    God's Country
    9
    Post Thanks / Like
    Re-map
    That's the problem with a generic rather than a custom re-map. Mine was done by JDE in Holland (a bit far to pop into) and Jeroen somehow removed the sensors from the ECU monitoring, hence no light for me. So it can be done, but don't ask me how!
    Kent
    11
    Post Thanks / Like
    Talk to MRC Tuning in Banbury. They should be able to do it. It will be the cost of a proper remap though......
    Black B5 S4 420BHP Sold
    Green B5 RS4 530BHP Sold
    Avus C6 A6 3.0Tdi 300BHP
    chrisjako's Avatar
    Feb 2009
    Post Thanks / Like
    i used custom code for my RS4 B7, had same issue - eng manage light came on after 2 weeks, went off and back on again occasionally then staeyed constantly on for 4 months
    i took it back and they put on the latest software, 5 months later it's still right as rain! :-)
    solaris's Avatar
    Slough, Berkshire
    335
    Post Thanks / Like
    I recommend Custom Code, they have mapped out my CEL error from my decat pipe
    If it's not longitudinal and it's not Quattro..it's not an Audi
    VCDS (VAG-COM) HEX-CAN USB cable carrying member
    2005 A4 DTM 2.0 TFSi Quattro :364Bhp/477NM - Mapped by MRC Tuning
    Hybrid K04 Project ongoing (link to Build thread)
    ATP FMIC for sale
    Jun 2010
    78
    Post Thanks / Like
    This is easy enough to code out, any tuner who knows what they are doing should be able to sort this, we code them out all the time
    2003 S3 - 263bhp remap by me, BMC panel filter, forge 007p. Genuine 19" BBS LM's
    soon to be stage 2 and running water to air chargecooler,
    Uxbridge
    152
    Post Thanks / Like
    Yep,
    MRC will sort it easily. About to get my pipe and remap and they mentioned that would happen.
    'Daytona B7 RS4 Saloon - with all the trimmings'
    Feb 2011
    Kent
    Post Thanks / Like
    Done these many times now, it's not a problem. just needs a proper tuner
