Monster MotorsportEM Tuning
Results 1 to 7 of 7
    Mar 2005
    Kent, UK
    VAGCOM on new RS4 - BY, 2007 - how do I use it?
    I have seen that I can buy an interface lead for about Ł12 but then there is the software sitiuation: which software do I need for the new RS4 and do I need to pay for it?
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,654
    I would have thought that a 2007 RS4 will require a CANBUS interface which I doubt a Ł12 cable is.
    Paul
    Gone not forgotten -
    92 Golf Gti Mark 2 16V.
    VCDS HEX-USB+CAN
    Mar 2005
    Kent, UK
    CANBUS
    Please explain, as this means nothing to me.... How do I tell?
    The911SC's Avatar
    Sep 2003
    South Wales - Swansea
    1,032
    the cheap leads use opto isolators and only support the old vag com software which will not code some modules. If all this doesnt make any sense to you then I suggest you save your 12 pounds and wait an see what you want to do.
    To get a real vag com cable, you will need to spend about 200 pounds then all of the programing software works.
    Porsche 997 Carrera 4 S - Black, Sport Chrono, Sport seats, PCM, Nav, Tel, Park assist and rear wiper (Yes!, its an option!)
    2012 Audi Q7 Sline Plus - Daytona Grey ,Nav+, Wheel upgrade, Storage and tow pack.
    Gone -2007 S5 4.2 ,2008 S3, 2007 TTC 3.2, 2007 RS4 Saloon, 2004 S4 Saloon, 2006 A4 2.0T Sline SE,2002 A3 3.2 Sline, 2001 A4 1.8T,2001 Boxster, 1983 911SC,1992 Corrado G60,1988 GTi.
    (Vag com owner)
    mas
    Jul 2005
    n yorks
    128
    early cars use what is called K&L lines - low speed single device talks at once.
    canbus is multiplexed and high speed.
    they use different pins in the socket, different signal protocols and different encoding.
    I dont think can is supported on the free version of the software.
    Look on ross techs site for details or ask the dealer (or google)
    but if you can afford a new rs4 why quibble about spending a couple of hundred on what is a very good and very reasonably priced product.
    and no the ebay leads are not going to be can
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,524
    ALL B7's need a lead that supports K-line, L-line AND CAN bus since some controllers (e.g. on an RS4 the 2 engine ECU's at addresses 01 and 11) only have a CAN connection.
    Spend the $$$ and get a genuine lead such as a HEX-USB+CAN or a HEX-COM+CAN (which is what I use on my B7 RS4).
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Or find someone who has it already that lives in your area.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
