Volks AutosMonster Motorsport
Results 1 to 9 of 9
    May 2011
    Glasgow Area-ish
    62
    Carbon fibre engine covers?
    I'm going to look at a B7 RS4 one thing that's set off alarm bells is that the carbon engine bits are missing? Never seen one with out them take it they were not optional?
    So lost? Stolen? Or are they easily broken by ham fisted mechanics?
    What jobs require their removal? Any of the normal service type things?
    VCDS & TPS Account holder.
    May 2012
    Kings Lynn
    910
    to my knowledge they are easily replaced. I saw one on ebay a few days ago actually also.
    Current - 2006 B7 A4 S Line Saloon 2.0T TFSI Special Edition, Unicorn stage 1 remap, Metallic Dolphin Grey, 18" TTRS Rotors, Ferrari Red front/rear Calipers, 3.5" Powerflow tailpipes, BOSE, Cupra R splitter, Chrome grille slats, S4 Mirror covers, Black/silver leather interior, Debadged, Arm rest delete, LED plate lights, Dectane LED Red/Crystal tail lights, HID 6k, RS 4 pedals, Rev D D/V, APR snub mount, NGK 7s
    Gone - 2005 B7 A4 Avant 2.0 TDI
    Feb 2009
    Aberdeen
    2,618
    Follow MartayMcFly On Twitter Visit MartayMcFly's Youtube Channel Visit MartayMcFly's Instagram Channel
    They were standard. Could be broken off I guess, but don't know there's much need for them to be removed unless they're doing cams or something.
    You can certainly get second hand sets online, or go to argon creative and get a full set of engine covers in matching grey carbon (the OEM ones are sort of yellow).
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    May 2011
    Glasgow Area-ish
    62
    Cheers for the replies. Just don't know that I should bother with a car that the add claims is excellent and well maintained when there is obviously lost or broken bits during careless maintenance. If they were really fragile I might have overlooked it.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,535
    Quote Originally Posted by weekenny View Post
    Sounds like the owner isn't very knowledgeable, makes you doubt his/her other claims too.
    Go see the car but be prepared to walk away, a good B7 RS4 is an absolute joy but a bad one is a money pit.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    May 2011
    Glasgow Area-ish
    62
    The idea is to go see and not buy unless it's perfect.
    I'm between an RS4 and going back to an Evo (this time a 9). Quite prepared to walk away seen a few money pits in my Evo days.
    StumpieT's Avatar
    Jan 2014
    20
    There is no reason apart from alternator belt or a decoke for the front piece to be removed. The rear carbon cover ( the larger 1 with the 4 rings ) needs to be removed to change the engine oil filter, so every oil service ideally. They are quite robust items and if removed correctly then they shouldn't get damaged. Both carbon covers should be removed vertically with no forward or backward or side to side movement. Each cove has 3 plastic pegs that press into rubber grommets.
    May 2011
    Glasgow Area-ish
    62
    Cheers mate, nice and detailed answer.
    Phil_D's Avatar
    Sep 2012
    Belfast
    13
    I have a spare set here if you buy the car and want them.
  1. Neuspeed Carbon fibre engine cover installed.
    By Rabbit222 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th September 2008, 21:19
  2. GB - ECS Tuning Carbon Fibre Engine Covers
    By RichA3Turbo in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th April 2005, 20:06
  3. GB - ECS Tuning Carbon Fibre Engine Covers
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th April 2005, 13:31
  4. carbon fibre engine cover
    By Danielson in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd November 2004, 17:42
  5. Carbon Fibre Engine Cover
    Last Post: 12th April 2004, 18:07
