Chris NottVolks Autos
    Danny Cawsey's Avatar
    Cawsey
    Dec 2009
    Valencia, Spain
    498
    B5 RS4 Engine Problems
    Hi, I'm an 8l S3 owner so not normally over this side but my boss has a 2000 b5 rs4 with a few problems and need some help diagnosing whats wrong with it.
    I took it for a drive today and its got a bit of a lumpy idle doesn't really settle. when on boost its got a very slight stutter and doesn't pull so smooth.
    He recently blew the turbos and has just had two brand new one's fitted a couple weeks ago not sure if this could be anything to do with it?.
    Anyway i checked for fault codes and here is what i got:
    16730 Camshaft position sensor
    16730 Engine speed sensor
    17930 Camshaft adjustment bank 2
    18010 Power supply b+ terminal 30, voltage too low
    Any Help would be much appreciated.
    Thanks, Danny
    AMD stage 2 map, BBS LM 19s, 20mm Momo Spacers, Black Diamond Discs, Ferrodo ds2500 pads, Milltek Exhaust, Pipewerx downpipe and Decat, Custom FMIC, 4 bar Fuel Pressure Regulator, Forge 007p, Forge short shift, Forge DV relocation ,Forge TIP, S2000 Filter, Sachs Race Clutch, Sachs Light weight Single mass flywheel, ForgeOil catch tank, De baffled Charge pipe & Polished, Polished Inlet Manifold, N249 Delete, PCV Delete, Red Engine Mounts, Forge Boost hoses, Angel Eye Headlights, LCR Splitter,
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,538
    Try clearing the fault codes and see which ones come back - some of those may be historical from before the recent work.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Sep 2013
    6
    Try Audi SRS forum they will point you in the right direction
    Feb 2009
    Aberdeen
    2,623
    Follow MartayMcFly On Twitter Visit MartayMcFly's Youtube Channel Visit MartayMcFly's Instagram Channel
    Yup, audisrs is the 'go-to' for B5s
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    Jul 2014
    Staffordshire
    Hi, I'm new to this but I have had three B5's and I'm not planning on getting rid of my present one which has been in my possession
    for the last seven years. I can tell you I had the same problem with the stutter it too run lumpy, I took it to Doug at MRC, and it turned out to be a Cam sensor.
  1. RS4 Engine problems
    By Tom Market Harborough in forum The Welcome Section
    Last Post: 11th February 2011, 20:11
  2. hot engine problem , can anyone help please ????
    By Jonny_doe in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th January 2005, 20:33
  3. rs4 engine in my golf mk3
    By golfrs4 in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 8th October 2004, 13:58
  4. rs4 engine in my golf mk 3(vr6)
    By golfrs4 in forum Volkswagen and other VAG
    Last Post: 1st September 2004, 12:38
  5. Engine Problem - 2.6 V6 - possibly ECU Fault -
    By imported_k15hvc in forum Classic Audi Forum
    Last Post: 11th July 2004, 21:40
