Chris NottMonster Motorsport
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By adamss24
Thread: Rs4 b7 4.2 oil - 5w30 or 5w40
    Feb 2013
    Manchester
    36
    Hi all,
    my car was serviced about 3k miles ago (not sure what oil is in there at the minute)
    I use the car as my daily commute (about 10 miles a day) with some light traffic. I do sometimes stretch its legs where possible.
    oil needs a topup, but unsure whether to put in 5w30 or 40??? Also what brand are you guys using?
    thanks
    rick
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,473
    Just look for an oil that meets the VW spec, don'[t worry about the grade.
    I use Castrol Edge - but check you get the one that meets the VW spec, there are several versions and not all of them do.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Jul 2007
    London
    3,089
    Use 5w40 fully synthetic oil. You could also use 5w30 but it's too thin and your chain tensioners won't like it and they might start rattling from cold.
    dualmono21 likes this.
    FOR SALE:
    Dec 2006
    barnsley
    932
    got to agree with above
    if your going to give the motor a tickle every now and again use the higher temperature rated 5w40
    5w30 is exactly the same as 5w40 at start up where it may change is if you thrash 5w30 long enough and get it too hot it will eventually break down and become too thin for the oil pump to pump correctly on start up hence rattling the chain on start up
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Feb 2013
    Manchester
    36
    cheers guys, what is the actual vw spec then? may call up opie oils and order a couple of litres...
    saw the link below...may go for the shell helix as i live right next door to a shell petrol station (conviniently!)
    Audi - Engine Oil - VW 503.01
    think i will top up with 5w 40 to be safe...but i guess it wont matter if it already has 5w 30 in there?
    Feb 2009
    Aberdeen
    2,523
    Your service book will tell you the spec you need (501, 503, 504 or 507 iirc, depending on service schedule), I personally use Edge 5w30.
    I can't see it mattering if you change 5w30 for 5w40 oil, but mixing different weights could well cause issues as I'm not sure miscible they'll be. Those 2 are pretty close in terms of viscosity etc so might not be to bad.
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    Dec 2006
    barnsley
    932
    i wouldnt advise mixing oils i would fill up with whatever was used at the last oil change
    right now there are two main types of synthetic oil
    one is a cracked oil with additives to give it its properties the other is esther based and they dont particularly work well with each other
    oilman's Avatar
    May 2008
    Sunny Cornwall / UK
    334
    Quote Originally Posted by dualmono21 View Post
    Hi
    There are three types of synthetic - hydrocracked (modified and refined mineral oil), PAO (proper lab made synthetic) and ester (top end of synthetic oils), this link explains the types.
    http://www.opieoils.co.uk/pdfs/tech-...scriptions.pdf
    They all mix together fine (in motor oils, ester based oils are a mix of PAO and esters), the only issue is that you are diluting the quality of the better oil by mixing it with a lesser one.
    Tim
    Use the code AUDIS and get 10% Club Discountoilman's website for VAG engine oil and much more - register for news and offersemail: sales@opieoils.co.ukphone: 01209 202944
    oilman's Avatar
    May 2008
    Sunny Cornwall / UK
    334
    Quote Originally Posted by S321BAD View Post
    Hi all,
    thanks
    rick
    Hi Rick
    The standard, easily available, choice for your car is a VW 507.00 spec.
    VW - Engine Oil - 507.00 - VW 507.00 motor oil
    They are fine to use and are required if it's on a long life service schedule.
    A lot of people have mentioned that their 4.2 engines can burn a drop of oil, so we sometimes recommend a good 5w-40 instead (also helps to keep the engine quiet).
    5w-40 engine oil | 5w40 oil
    Out of those, the best ones are the Fuchs/Silkolene Pro S, Millers CFS/CFS NT, Motul 300V, Redline and Gulf Competition. They need to be changed annually or at 10k, whichever comes first and are not approved by VW, but will offer the best level of protection.
    Tim
    Feb 2013
    Manchester
    36
    cheers Tim!
    i used Millers Nano drive in my old 8p s3 and definately noticed a difference...
    i think im going to top up with 5w 40 millers but not sure which of the 2 to go for? i will eventually use millers for the actual oil change in a few months anyway...
    can you recommend which is best between the two millers options and why?
    oilman's Avatar
    May 2008
    Sunny Cornwall / UK
    334
    Hi Rick
    As there is the potential power gain with the CFS NT, I guess you could say that is the better of the two oils, but if you are just topping up, I'd probably save a few quid and go for the Millers XF Longlife as a litre or so in a sump full of oil isn't going to make any difference.
    Millers Oils XF LONGLIFE 5w-40 Full Synthetic Engine Oil
    Tim
  1. 5w30 (502.00) spec vs 5w40 Racing Oil
    By _G_ in forum General Automotive Chat
    Last Post: 26th July 2012, 08:26
  2. 5w30 vs 5w40?
    By _G_ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th June 2012, 21:34
  3. 5w30 or 5w40?
    By S3 finatic in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th May 2011, 14:48
  4. Halfords 5W30 VW/Audi Fully Synthetic 5L Oil, anyone used this?
    By jimbo_123 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th June 2009, 09:49
  5. RS4 B7 oil & fuel consumption
    By luckie in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 25th February 2009, 13:55
