AH FabricationsBadger5
    Feb 2013
    Manchester
    36
    2006 RS4 B7 SALOON - DRC PROBLEMS!
    Hi All,
    I am sure this has been covered a million times before but,
    went on a journey from Manchester to Birmingham over the weekend, the car behaved perfectly well. As soon as i came off the motorway and onto a 30mph zone, i heard some clunking from the rear drivers side (Almost as if it was coming from under the passenger seats) - it got progressively louder the more i drove it (had no choice but to carry on going to my destination). thought it may have been a bush or something.
    Anyway got the car back home to Manchester and took it to a local mechanic - looks like passenger rear side Shocker is leaking (which is strange since most of the noise is coming from the drivers side rear).
    Anybody have any advice as to what to do in terms of repair as i have read alot of horror stories regarding DRC online. Obviously i want to avoid breaking the bank.
    Do i replace both rear shocks and recharge system? what about the central valves? i guess if they hold pressure once recharged they are fine? or do i have to replace all four shocks and central valve (correct me if i am using the wrong terminolgy?)
    Or do i scrap DRC altogether and go for aftermarket coilover kit?
    i called Audi today and they told me the rear shocks are around £200 each and the central valve costs £900 and there are 2 of them!
    any advice/experiences ?
    thanks
    Rick
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,525
    Quote Originally Posted by S321BAD View Post
    I had a similar noise last August - the bad news is that's the DRC valve block, so as well as replacing the leaking shock absorber that caused the problem you'll need to replace the valve block as well - and that's the expensive part.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Feb 2013
    Manchester
    36
    Hi Dave,
    i spoke to Audi and they said the valve block wont need replacing as long as it holds pressure?
    they also sais there are 2 valve blocks at £956 each?!?!
    i guess only time will tell!
    Feb 2009
    Aberdeen
    2,605
    Follow MartayMcFly On Twitter Visit MartayMcFly's Youtube Channel Visit MartayMcFly's Instagram Channel
    For a start, the DRC dampers are paired diagonally so if you had to replace one rear, I'd say the opposite front is the other one to check but most of the time a leaking damper can be replaced independently. The pairing is why there's 2 valves to worry about too. It could be that both of the rears are leaking though. If a valve has gone too (usually when the system is running without pressure for a while) then you're better to look into coilovers. A set of KW V3s will set you back about £1500, 2 dampers and a valve will be about the same. If you're ever considering going for coilovers, now could be the time. The other option would be to go for after-market dampers and just get rid of the DRC worry.
    Only Audi can recharge the system.
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    Feb 2013
    Manchester
    36
    cheers Marta,
    having done some extensive reading on various forums/sites and spoke to some specialists, i am going to swap out the drc for coilovers as you suggest,
    been looking at Bilsteins B14 - seem good value at £975 for the kit...is it really worth the extra £500 for the kw's considering i am never going to take the car on a track and its literally a daily driver to work and back?
    Feb 2009
    Aberdeen
    2,605
    cheers Marta,
    I think the comparison is B14 vs B16 (which are fully adjustable). If you're happy with the ride on the B14s, then go for that, but if you think you even might want the adjustable dampers then get the fully adjustable ones. Added bonus of coilovers is you can lower the car. I didn't really plan to lower mine, but the SS+ comes with such reverse rake it had to be done when the rear springs went.
    Hunt is over
  1. How to fit Auto Lights/Wipers & Auto Dim Mirror to 2006 RS4
    By JR Tuning Ltd in forum General Technical / How To
    Last Post: 20th November 2010, 19:02
  2. H&R springs for RS4 B7 saloon
    By JamesS4cab in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 22nd February 2010, 16:43
  3. rs4 bumper and grille problems (help)
    By S3 chj in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th October 2008, 17:29
  4. 14k for a 2006 rs4????
    By 205man in forum General Chat
    Last Post: 10th March 2007, 15:13
  5. Rs4 bonnet grill fitting problem
    By imported_Yaseen in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th January 2005, 13:24
