Volks AutosJMB Retrofits
Results 1 to 11 of 11
    Aug 2012
    USA-Rhode Island
    6
    New Owner needs input
    Hello all,
    I am a new owner of an 07 RS4 which is great this far but I have a few quick questions I thought I would pass by you all. Any input is appreciated!
    I have a fairly nasty clicking from a slow start which seems to come from my left rear rotor. This sounds like the rotor and base plate are loose but I find that hard to believe. Thoughts?
    When I hard turn the steering wheel to full lock on either side I hear a slight whine, is this to be expected?
    I think I need a front right wheel bearing, is this common at 50K?
    So far the car is great. I am a BMW convert (e46 M3 and e39 and e28 M5), I feel all grown up and like being able to drive the car without beating on it, something I was never able to do with the M-Cars. Good thing I still own the e28!
    Thanks much for your input in advance.
    db
    http://swingpad.com/db/RS4.JPG
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,434
    Welcome to Audi-Sport.Net. Nice looking car. Where are you located? One of the guys will be along to advise you. Hope you enjoy the forum. x
    Aug 2012
    USA-Rhode Island
    6
    I am US based, in Rhode Island Specifically.
    Thanks,
    db
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,532
    Quote Originally Posted by dbenson View Post
    Are you sure there isn't something like a stone stuck between the rotor and the backplate?
    Yes, full lock puts a significant load on the power steering pump which makes it whine.This is totally normal.
    What makes you think that?
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Aug 2012
    USA-Rhode Island
    6
    Dave,
    Thanks for taking the time and answering the power steering question. That is what I assumed but I wanted to ask around.
    As for the Rotor/Rear Drivers side wheel clicking. This issue is very mechanical and seems to happen upto but not beyond 10MPH and usually after I have backed up. It really sounds like a two part rotor being loose but all seems fine in that department. Def not a rock. Could I have a missing rattle clip in that caliper? I would expect that to make more nose in bumpy conditions.
    With regards to the wheel bearing, I am a wrench and recognize the tell-tails of a wheel bearing going with regards to the harmonic noise it usually creates. I was curious if this could just be due to milage or if they have a history of failure. Obviously the slotted rotors can elude to this sound as well but not usually at a slow steady pace without the brakes applied.
    Again, thanks much for the insight.
    db
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,532
    Worth checking the rattle clip, definitely not a common problem - can't remember anyone else posting about it on the many RS sites I frequent.
    Again not something that is a known problem, even on cars with 80k+ miles.
    Aug 2012
    USA-Rhode Island
    6
    Hello again everyone.
    I just wanted to bump this again due to both my rear calipers/Rotors making the same noise at slow speeds.
    Any help would be appreciated.
    db
    Aug 2012
    USA-Rhode Island
    6
    Hey Folks,
    My lack of knowledge on the RS4 is at the root of my rotor clicking issue. I did not realize the RS4 came with X-Drilled rotors OEM while my car has two piece slotted rotors. I have been unable to identify the manufacturer of the rotors but they are slotted with polished aluminum center Hubs.
    Any insight is appreciated.
    db
    Jun 2011
    Wellingborough
    1,169
    have you checked the bearings?
    my C6 RS6 does this and on the rs246 forum its down to the bearing according to owners who have had the issue sorted.
    SLOW REPLIES BETWEEN 22nd - 30th June due to been out the office, please bare with me. Thanks
    Bi Xenon Projector kits starting at £79.99 per pair.
    EM Tuning Lighting.
    Aug 2012
    USA-Rhode Island
    6
    All,
    I got the bottom of my clicking. It seems the Air pressure sensors became free inside the tires and were hitting the rim at slow speeds, causing the nasty clanking sound I was having.
    As for the breaks, it sure looks like I have JHM rotors all around which I am happy about. Any insight on which kit I have? I believe them are the OEM replacements but who knows.
    Thanks,
    db
    Jun 2011
    Great Melton Norfolk
    1,348
    Glad you got it sorted, bit of an odd problem !
  1. 1.8 T (190) Servicing and Tuning ... New owner needing guidance !
    By Stu!!! in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th February 2011, 05:37
  2. New Audi S4 (54) Owner needs advice!
    By lvs409 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th March 2009, 20:26
  3. Advice needed for new owner Plz S3????
    By ollyste in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th November 2005, 19:17
  4. New to the board-just bought an Allroad-need input please
    By in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th July 2005, 00:03
  5. New S3 Owner needs specialist advice !!
    By BigSimon in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2005, 13:18
