AH FabricationsSky Insurance
Page 1 of 2 12 LastLast
Results 1 to 40 of 42
Like Tree1Likes
Thread: AMI on a B7
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,538
    AMI on a B7
    I had previously swapped the pre-2010 RNS-E in my 2006 B7 RS4 to a 2010 RNS-E (an A3 one with the faceplate swapped) so that I could play SDHC cards instead of SD cards.
    Today I finally fitted the 8P0 057 785 AMI that had been in my study for over a year, so I now have a 250GB hard drive with all my music sitting in the glovebox.
    It took about 2 hours (I had previously swapped the audio leads into a 32-pin AV connector that the RNS-E uses) to route the cable alongside the CD changer cable (so I could easily swap back if needed) and solder the 4 connections (+12V, GND, CAN Lo & CAN Hi). A couple of minutes coding from 309753 to 309721 to enable the AMI and disable the CD changer, and I had a working AMI.
    AMI unit in glovebox:
    Hard drive appearing on MEDIA menu:
    Album playing from hard drive:
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,538
    AMI on a B7 RS4
    Provided you have retrofitted a 2010+ RNS-E, you CAN have AMI...
    See http://www.audi-sport.net/vb/audi-s4...29-ami-b7.html
    27,129
    You sly git PD, well done mate, great install, so it will work even if the gateway doesnt support the unit on the network, very very interesting & greatful as I was studying how to run a secondary canbus gateway on the car from the 8P/TT/R8 to allow coding it as live.
    Have you tested with an ipod/iphone as yet mate?
    DIS shows data ok?
    MF controls working with AMI?
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,137
    It's a must have!
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,538
    I'd seen posts on Audi Forum where people had tried it on a B7 and it had worked, so I gave it a go!
    No, I haven't sold my soul to Apple
    DIS shows data ok?
    Yep, shows the track name on the top line and AMI on the second line.
    Dunno, I've got a "proper" RS4 steering wheel not an MFSW
    Feb 2012
    West Wales
    161
    Will this work with the MK1 RNS-E?
    27,129
    No as ami is only supported on mk2.
    chasdrury's Avatar
    Jan 2005
    Sheffield, UK
    272
    Do you have to mount the AMI in the section on the glove box, I mean, could you dismantle it an stick it somewhere else? I have a PS 2 on the top shelf so no room for the AMI there.... I'm thinking glovebox for the cable to appear with the gubbins under the centreconsole, or present the ami cable to where the ashtray would be?
    I have a B6 A4 but see it will work on a car from audiforum.us - what coding and cabling would be required?
    Chas
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,538
    Quote Originally Posted by chasdrury View Post
    You don't have to but it's designed to have the same fixings as the CD changer, so I just pulled out the CD changer and put the AMI there.
    Coding? - just change the RNS-E coding to 0xxxx2x to enable the AMI.
    Cabling? - I bought an 8K0 051 592 from the local Audi dealer and modified it, but some eBay sellers include the correct cable for an RNS-E if you buy the AMI from them (tell them it's for an 8P A3 to get the right cable).
    Dec 2006
    Herne Bay, Kent
    74
    Do any of the Seat Exeo units fall into this category or do I need to buy an A3 one and swap the front?
    27,129
    I cant see ami showing for seat in etka, shows the unit but no part no. or price, but thats not to say you couldnt retrofit it.
    Dec 2006
    Herne Bay, Kent
    74
    Thanks, I just wondered that it might be easier than the faceplate swap on an A3 unit.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,538
    Quote Originally Posted by rhinoman View Post
    You would have to put up with a faceplate with SEAT on it though...
    May 2013
    13
    Hello,
    I just tried it.
    It does not work ...
    I have a 193B and RNSE AMI 8P.
    The rns-e show "incompatibility".
    Is it normal to still see the CD changer with AMI even after a (and more) reset RNSE.
    Is it normal when a iphone / ipod is not powered at connection?
    any idea?
    thanks
    May 2013
    13
    Hello,
    I just tried it.
    I have a 193B rns-e and AMI 8P.
    any idea?
    thanks
    27,129
    It does work, what exactly have you done, did you use new wiring?
    May 2013
    13
    I bought this cable from Kufatec.
    Kabelsatz Audi Music Interface AMI - RNS-E Audi A3 8P-37575
    I checked the wiring PIN ok
    Recode the rnse with ..XX21
    Reset the RNSE.
    When I turn the RNSE, It has in part a media AMI tab grayed out, it is indicated as "not connected".
    When I disconnect the plug on the back of the AMI and I reconnected, the RNSE says "boot" and "incompatibility".
    that's all.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Yes you can have AMI and CD changer, when do you get the incompatibility message?
    Do you have the right Ipod cable with a blue band on it?
    May 2013
    13
    I made several tests:
    with CD-changer and AMI connected with the RNS-E coded for both
    with CD-changer and AMI connected with the RNS-E coded for AMI only
    Without the CD and AMI plugged and RNS-E coded for AMI
    Always the same result ....
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    I have fitted several AMI's to B7's and even an A2, it works, so you have a faulty part or your doing something wrong.
    May 2013
    13
    Quote Originally Posted by s8craig View Post
    I bought from my dealer a kit 4F0051510S with a cable for ipod / iphone 4F051510R (with a burgundy band) and a USB cable.
    I did some tests with iphone 4S and an old ipod video classic 60GB
    You think it is that this is the AMI does not work?
    What type of RNS-E with you made ​​the arrangements?
    193B, G others?
    It works with a 193B?
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    I have used 193B & G units, I thought the burgundy banded was for MMI 3G+ that could display video. I have heard reports of issues with that cable. I would use the blue banded K cable.
    What message do you get with nothing connected to the AMI?
    "No device attached" or something similar? and then the incompatibility message when you connect an IPod?
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,538
    It definitely DOES work, I've been using it every time I driove my B7 RS4 since I fitted the AMI last year.
    Quote Originally Posted by shreck View Post
    The picture on the Kufatec website shows that as a Quadlock only cable - which means it can't work with the RNS-E.
    The AMI connects using the Aux In connections which on the RNS-E are not on the Quadlock, they are on the AV connector.
    Other things to check:
    - that you have bought a CAN bus AMI and not a MOST fibre optic bus AMI
    - that you have a 2010+ RNS-E and not a pre-2010 RNS-E
    Sorry if some of those seem obvious, but those are things that some people have missed when trying to do this retrofit.
    NHN likes this.
    May 2013
    13
    yes it's true.
    There are 2 type of connection on the cable.
    The quadlock is used to retrieve the can bus high and low, the ground and the +12 v
    the 32 pin connector with 3 audio connections ...
    May 2013
    13
    Ok
    but the problem is that no log AMI I still have the same message ...
    You have installed AMI on B7 RS4 with 193B?
    Thanks for your Help.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    I didn't understand your last post. Sorry
  28. #27
    May 2013
    13
    with or without an iPhone/ipod connected i have the same message :"incompatibility"
    do you have already install an AMI in a RS4 B7 with a 193B rns-e?
  29. #28
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    I cannot say for sure wether I have fitted with B or G, but it does not matter which is used. I have fitted into B7 RS4 AMI and RNS-E with no issues.
    In my own car I have RNS-E B model with AMI and it is an A2 which is very similar to B7 RS4 electronics. K-line, infotainment canbus etc.
  30. #29
    May 2013
    13
    ok thanks.
  31. #30
    27,129
    That's the correct cable as its the 8P version.
    I would reset the rns & see if it comes up, make sure your ami cable is the correct version & the ami unit is correct aswell as Dave has stated, I hazard a guess its the wrong ami cable or ami unit.
  32. #31
    May 2013
    13
    The AMI Unit is an AMI CAN for A3 8P parts number 8P0 035 785. And the cable is made for A3 8P too.
    The +12 v is stung on the connector D pin 15
    The ground is stung on the connector D pin 12
    can bus high on pin 9 and low on pin 10.
    Sound goes to pin 6,21 and 22 on the 32 pin connector.
    For me the cable is ok. no?
    Reset? I have done several times by pressing the radio and the setup buttons.
    What are the coding instructions step by step on a 2011 A3? I would like to test the AMI on another car to see if it works or not ...
    thank you
  33. #32
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,538
    There's only one step:
    - change the coding of the RNS-E to 0xxxx2x, see Audi Radio/Navigation System (RNS-E) - Ross-Tech Wiki (AMI is shown as "digital radio" for some bizarre reason known only to Ross-Tech).
    BTW by posting in this Forum and in the RS4 Forum you're splitting your replies which isn't helping you get this solved quickly - double posting is never a good idea... but listening to s8craig is ALWAYS a good idea, he has so much experience and knowledge.
  34. #33
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,538
    shreck has also started a discussion on this problem in the original thread http://www.audi-sport.net/vb/audi-s4...29-ami-b7.html
    I suggest we merge the discussion back in the original thread, splitting our replies isn't helping shreck solve his problem.
  35. #34
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Hadn't seen that Dave, seems he has everything wired up correctly, can't understand why it isn't working except for faulty parts.
    But I would like to see it.
  36. #35
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,538
    It appears you have the correct parts and adapter cable, so as s8craig says it's looking like faulty parts.
    Where did you get the AMI from?
  37. #36
    27,129
    I will get it merged, please keep all posts in one thread from now on.
  38. #37
    27,129
    I am with Craig on this & as per my post in the other thread, the red ami cable isnt shown compatible with the 8P at all, maybe this is where your issue lies as I've never seen the red/burgundy cable used on the 8P ami units, always seen red used on the full mmi & the ATP search in etka for all models shows from 09 onwards for all cars with full MMI only.
    Also I believe this is why its either saying not installed or not compatible because of the said cable fitted, I had the similar response when I was messing with a B8 CAN AMI unit I plugged into an 8P out of research
  39. #38
    May 2013
    13
    Quote Originally Posted by PetrolDave View Post
    This applies to B7 ok.
    but for A3 8P it seems to be coded module 19 (can bus) and 2F module (multimedia player 3) right or not?
  40. #39
    May 2013
    13
    I bought it used.
    To be sure I would test tomorrow installation in my A3 sportback tomorrow.
    I also will test the USB cable had the same reference for all AMI
  41. #40
    May 2013
    13
    the daily news !!
    Already contrary to what I said above the "incompatibility" message appears only when you connect a device.
    Test with the USB connector and connected my iPhone 4S via its USB cable. Result: Incompatibility. Normal?
    Test with a USB key: first result incompatibility.
    I started to believe that the AMI unit was a faulty parts.
    While I had everything disassembled I have an idea. I work on Mac ; is the USB stick that I used is fat format?
    Not. So I redid the test after formatting.
    And everything works.
    So S8craig was right, i have a problem with my iphone connector who is not the good reference.
    I have two questions anyway.
    it is normal that the iphone connected via the USB cable is not functional?
    With the 4F0051510K cable (with blue edging) when the iphone is running, is it possible to have in the car speakers music and sounds of an application running in the background?
    In any case thank you very much for your help.
  1. Retrofitting AMI, is it possible?
    By ryanstewart9 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th July 2012, 22:53
  2. Q5 AMI
    By Dogzyboy in forum Parts Requests
    Last Post: 26th November 2011, 10:52
  3. Do I have AMI? :-)
    By Tracebuzta in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th July 2011, 00:48
  4. Do i have AMI?
    By KayP in forum Satellite Navigation
    Last Post: 19th April 2011, 07:53
