Volks AutosSky Insurance
Page 2 of 2 FirstFirst 12
Results 41 to 42 of 42
Like Tree1Likes
Thread: AMI on a B7
  1. #41
    27,094
    Just buy the correct ami cable for your unit/car & test as you're just pissing in the wind atm with incorrect parts.
    Depends on the app, but if you're referring to speed camera app, then yes I've seen an app work inconjunction with music playing, but this is all down to setup within the app & music I guess, something you'll have to test yourself.
  3. #42
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Yes Iphone with USB will NOT work.
    MAC formatted devices do NOT work.
    FAT 32 is perfect for the AMI
    Quote Originally Posted by shreck View Post
    the daily news !!
    I made several tests:
    Already contrary to what I said above the "incompatibility" message appears only when you connect a device.
    Test with the USB connector and connected my iPhone 4S via its USB cable. Result: Incompatibility. Normal?
    Test with a USB key: first result incompatibility.
    I started to believe that the AMI unit was a faulty parts.
    While I had everything disassembled I have an idea. I work on Mac ; is the USB stick that I used is fat format?
    Not. So I redid the test after formatting.
    And everything works.
    So S8craig was right, i have a problem with my iphone connector who is not the good reference.
    I have two questions anyway.
    it is normal that the iphone connected via the USB cable is not functional?
    With the 4F0051510K cable (with blue edging) when the iphone is running, is it possible to have in the car speakers music and sounds of an application running in the background?
    In any case thank you very much for your help.
  1. Retrofitting AMI, is it possible?
    By ryanstewart9 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th July 2012, 22:53
  2. Q5 AMI
    By Dogzyboy in forum Parts Requests
    Last Post: 26th November 2011, 10:52
  3. Do I have AMI? :-)
    By Tracebuzta in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th July 2011, 00:48
  4. Do i have AMI?
    By KayP in forum Satellite Navigation
    Last Post: 19th April 2011, 07:53
