W8 PerformanceRevo Technik
    eddieantifreeze's Avatar
    Jul 2011
    162
    Post Thanks / Like
    Viewing an RS4 avant (B5) tomorrow
    apologies for the annoying thread guys... i did do some searching and couldnt find anything definitive. I'm just hopping over from the A3 forum......
    I am viewing/test driving a B5 RS4 avant tomorrow, its got 120,000 miles on it and was just wondering if there any known niggles i should be looking out for? (eg. RS6 suspension issues)
    I normally do way more research on my own but I have been looking at RS6's but i think the RS4 is tempting me.
    Any help would be really appreciated guys...
    97 Green 1.8T - Stage 1 R-Tech map - SOLD
    2001 B5 RS4 Avant - Misano Red
    Banned
    Aug 2010
    823
    Post Thanks / Like
    get on audisrs, sadly the rs4 section doesn't get too much attention here
    but from what i have learnt you need to consider the following.......
    Clutch - when was it last changed,, if it's older than 50k there's a chance it'll need doing during your ownership, that's be £1,000
    Tyres - much life left, a good set will cost you £200 a corner
    Brakes - pads and discs for the front will set you back £700, and about £500 for the rears
    Dump valves - ever been changed? if they haven't there's a strong chance they are not working correctly, these will cost £40 each
    EGT sensors - have these been changed? at 120,000 they could well be on their way out, so the newer the better, these cost about £180 each
    Lambda sensors - not a common problem, but there's 3 of them and they cost around £300 each so if they have been changed at some time that's a bonus
    MAF - like all vag cars, the mafs do go faulty, make sure it's been changed at least once during it's life, most RS4's have gone through one in their life, these cost about £180
    Gearbox - 1/10 tries to get the gearbox into first or reverse when stationary often gets blocked, this is pretty normal on these and VERY common, a little gas or simply knocking the car into second instead before selecting first or reverse helps - again, this only happens in 1 out of 10 tries, probably even less, sometimes just holding the clutch down for a bit before selecting gears helps too, if that, however, there were recalls unrelated to this, 1 2 3 and 6 syncros were changed on mine by audi
    Engine - pretty solid, however, some have had cam issues, i suggest you get them checked for wear, but to be honest at 120,000 miles i think you'll be fine, it's more the lower mileage cars that people worry about, however, getting them changed can cost around £2,000 !!
    Thermostat - makes sure it has been changed, make sure the car heats up very quickly and after a drive, it;s only a £19 part, but it can take around 5 hours to replace !!!
    Radio - bad reception can be caused by a loose areial above the amp in the rear left side compartment
    Turbo's - make sure there are no leaks or odd sounds, i'm no expert, but changing these on an rs4 can create a bill way over £2,000
    Suspension - check all the springs for cracks , more the rears than the front
    that seems to be what i have picked up from my experience, power delivery should be very smooth, nothing like a mapped 1.8t, power should continue to increase until the red line, if you find it;s brutal low down and looses power higher up, chances are it has been mapped........ like i said, get on the srs site, maybe even give one of them a little dosh to come and go over it with you, they know their stuff
  4. Thanks S3 Rav thanked for this post
  5. #3
    dest's Avatar
    Jul 2007
    Northants
    191
    Post Thanks / Like
    Go armed with vagcom if you can, I viewed and RS4 on autotrader a week a go, and it showed up a fair few potentially expensive faults that would need sorting!
    Avus B5 RS4
    Gutted downpipes, non-res Milltek, custom MRC remap, H&R ARB's, B7 RS4 brakes, oil cooler, Tanoga short shift
  1. 2007 Audi RS4 Avant 4.2 Rs4 Avant Quattro 5 door Es...
    By Ebay RSS in forum Ebay RS4 Cars
    Last Post: 2nd December 2011, 14:10
  2. Audi RS4 Avant Estate RS4 AVANT MASSIVE SPEC REAL EYEFU
    Last Post: 1st December 2011, 03:50
  3. 2007 Audi RS4 Avant 4.2 Rs4 Avant Quattro 5 door Es...
    Last Post: 27th November 2011, 12:30
  4. Newbie Hello and Bose or not - help please viewing car tomorrow
    By tt ted in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th July 2010, 23:04
  5. Replies: 49
    Last Post: 21st September 2008, 13:03
