Backdraft MotorsportDNA Tuning
Results 1 to 18 of 18
    Banned
    Aug 2010
    823
    Post Thanks / Like
    RS4 b5 progress thread
    right, now the s3 is gone, i thought i'd put a progress thread up about my current rs4 b5
    firstly i sold the s3 for a few reasons, it was only ever going to be a stepping stone for an rs4, i would have kept it longer but my insurance for an rs4 was only £100 more per annum (compared to £3,000 more last year), the other reason for the sale was the desire for a more powerful car with more space, many people throw large amounts of cash at their 1.8t's only to lose it all in the long run, so to me it was a no brainer, just buy an rs4, i also could not stand the haldex unit on the s3!
    so after putting £3000 into putting my s3 in a sound mechanical condition (cambelt, fluids, tyres, brakes, suspension and fixing other various problems), i decided to sell it after doing around 15,000 in it.
    the first thing i looked for when buying an rs4 was low mileage, a sunroof, aluminium mirrors, rails and windows frames as well as a dark colour with a centre armrest, full leather and a bose system, things like the anti glare mirror and satnav had no pull with me.
    i also knew how much simple servicing this vehicle would cost, cambelt change around £700, brakes around £1,000, clutch around £1,000 and tyres around £700, so finding a car with the above work carried out recently was crucial
    i managed to find one not too far away from me, popped over and had a look and was instantly attracted to it, 76k, new clutch at 55k, new brakes at 69k, cambelt at 70k, and brand new tyres, it also had new dump valves, egt sensors and a maf at 55k, it was also finished in a non-standard colour, santorini blue, it had everything i wanted, the car was 100% standard, but i knew that with all the recent work done to the car I’d have money to spend on getting it tuned up etc. after the test drive, i left a deposit and collected the car within 2 weeks.
    coming from motorcycles i knew the car would not be "scare me quick", it wasn't, i liked it, real smooth power from low down with a final punch at about 6,000 rpm, ok let’s be real, compared to the mapped s3 i had it was an animal, power kept coming in the higher rev range, something the 1.8t lacked due to the single turbo not being able to provide boost, i could also tell it had a proper 4 wheel drive system, fuel consumption was what i thought, 33mpg on a run at 70mph (460 to a tank) and a poor 19mpg around town, so close to around 250, obviously this is with light footed driving, put your foot down and these figure's will drop very quickly
    the car is heavier than the s3, but only by around 170kg and considering the rs4 was a little higher than my s3 i think a lowering spring on each corner would give similar if not better handling capabilities than the s3 simply because of the width of the axles and the wider 255 tyres, the standard suspension was still good for a 10 year old car, felt firm and coped with the power fine, something i could not say about the s3's 10 year old suspension, there was a small amount of body roll, but not much and the usual under steer when coming into a corner hard and over steer when coming out too hard
    the brakes are better than that of the s3's, by far, then again, it has 380mm discs on the front with huge pads, i also noticed the engine braking was better, i suppose this is down to the constant 4 wheel drive system, the only thing i have to get used to is the heavier flywheel as the engine does take a little longer to spin down
    the gear box is very smooth whilst driving, better than that of my old s3, although 1st and reverse from neutral require you to wait around half a second with the clutch down if you want a smooth engagement, however 9/10 times it goes in without waiting easily, i've just learnt to wait so i avoid that 1/10 chance lol, i’ve also had to get used to the heavier flywheel as engaging the clutch too quickly provides you with a slight jump forward when changing gear, so I need to work on letting the gas off a little earlier and lift the clutch up slower, the car also manages to do 60 in second gear lol!
    the car is bigger upfront and maybe a little bigger in the back, the sound system is MUCH better in it, the thing that annoyed me with the s3 was that silly sub hidden away, luckily the rs4 speakers produce their own bass, the boot also looks a lot better although i can not picture my old s3 boot as i never really used it lol, the inside of the rs4 just feel better to, even the headlight flasher feels smoother lol and the carbon fibre really make the rs4 feel that little bit special
    the paint work and panels also seem to be of better quality (maybe my s3 was a bad example) and the rs4 wide stance just does it for me, the big wheel arches really make it stand out, my car is de badged though and very few people know what it is, it's also very quiet inside and quite quiet on the outside
    all in all i am very happy with the change of cars, i love having an oil temp display as it lets you know when you can give it some, something the smaller audis lacked i believe, i;ve already had to call the aa out as i ran out of fuel on the way home lolol!!
    i will update this thread with random posts and plans etc, not really any good at this kind of thing....... i only have one pic so far, i will get more
    the next post will be "future plans"............
  2. Likes ScottB5 liked this post
  3. # ADS
  4. #2
    Banned
    Aug 2010
    823
    Post Thanks / Like
    current plans so far are to fix the bad radio reception (told to look at the wiring near the cd changer), get the centre hub cap put on (was left off by mistake so it's in the post) one of the wheels and try to fix the rear heated windows (2 strips don't work across the full length of the glass) - yes major problems aye !
    i also want to get the paint work looked at and have any stone chips and scratch marks professionally repaired, there's maybe 4 on the bonnet and the 3 scratches on the bumper with the odd chip scattered here and there
    handling wise, i will probably go down the bilstein route and upgrade all shocks and springs
    power wise i will almost certainly have wagner 3 inch downpipes with 100 sport cats and a miltek system fitted as well as a map, this should increase the power from 325/380 to 450/450
    the odd mod so far will be sourcing an anti glare rear mirror and changing the bulbs all round to LEDs (everything minus the headlights)
    other than the above i can not think of anything else !!
  5. #3
    JtotheD's Avatar
    I'm married to the music
    May 2011
    Bournemouth, Dorset
    455
    Post Thanks / Like
    looks the dogs fella. really interesting to read this, as I love the rs4s looks and appeal, and am using my s3 as a stepping stone also for an rs4. (possibly!) lol
    S3 8L Ming Blue
    Build/project thread
    check it out!
    South Central/West Meet : March<---- CLICK
  6. #4
    Banned
    Aug 2010
    823
    Post Thanks / Like
    lol thanks
    have fixed the bad reception, as pointed out on audisrs.com it turned out to be the connection above the cd player, the clip had broken for the aerial, so a cable tie fixed it....... will get it replaced if possible
  7. #5
    www.badger5.co.uk
    May 2004
    nr Glos
    3,876
    Post Thanks / Like
    hope your stock clutch survives the increased power
    **BUY MY AUDI S6-2000MY 4.2V8-£4750ono**
    http://www.badger5.co.uk, Tel:01453822880, Mob:07976 800775
    bill@badger5.co.uk
  8. #6
    Banned
    Aug 2010
    823
    Post Thanks / Like
    i am sure it will be fine, no one else has mentioned any problems, the standard clutch is good for about 500lb ft at the crank
    there's a few other things i want to get done, there's 2 non standard electric appliances in the car, a nokia car unit and a snooper speed camera detector, i plan on removing these this weekend after i work out what they are wired into, have ordered the radio remove tools as it looks like it wires back to that..... i'm not a fan of clutter, so hopefully i can remove it all easily
    neither of them work, so there's no point leaving them in
  9. #7
    www.badger5.co.uk
    May 2004
    nr Glos
    3,876
    Post Thanks / Like
    hmmm. I must have been seeing things on the std clutch we just removed from a local RS4 then
    less than 18moths old stock unit
    dont launch it ffs..
    bill@badger5.co.uk
  10. #8
    Banned
    Aug 2010
    823
    Post Thanks / Like
    LOL - like any car it totally depends how you drive it ! i am sure you could nuke a oem s3 clutch in a day if you keep launching !!
    first problem so far, although covered by the dealer warranty.........
    dodgy thermostat, seems to be open all the time, £19 part, but 6 hours labour to change as it's behind the cam belt LOL!!
    a3 tdi hire car ftw !!
  11. Thanks graemep thanked for this post
  12. #9
    Banned
    Aug 2010
    823
    Post Thanks / Like
    had the car back for about 2 weeks now, the thermostat fixed the problem, it warms up much quicker and so does the oil, timing was also slightly out, so it;s spot on now
    i have recently added a parrot mki9200 bluetooth system and next on my list will be a wiper change all round and a change of bulbs to whiter bulbs to go with the HID's
    here's a couple of pics (centre hub has been put back on)
    car will go into mrc for a full fluid change and full service as well as a tune up hoping to take it to around 480 bhp / 480 lb ft
  13. #10
    Oct 2008
    Glasgow
    254
    Post Thanks / Like
    To get to 480 you will need to spend a few ££££. I wouldnt like to be paying for that bill lol
  14. #11
    Banned
    Aug 2010
    823
    Post Thanks / Like
    costs are quite okl to be honest - £3,500 will do it for sure, possibly even £3,000, probably even less after you sell the RS4 oem exhaust system with down pipes to an S4 owner....
    trying to get another 150lb ft torque and another 100 bhp out of an s3 or similar would cost a hell of a lot more, and then you'd be left with a car that has no grunt and needs to be above 4,500 rpm to get anything out of it!
  15. #12
    dest's Avatar
    Jul 2007
    Northants
    191
    Post Thanks / Like
    For 480-500bhp you need to be looking at gutted downpipes or upgraded, fuel pump and a fresh remap.
    I fitted a front mount cooler to my S4 (running mainly RS4 engine) to crack 500bhp, it made a huge difference to the car
    Avus B5 RS4
    Gutted downpipes, non-res Milltek, custom MRC remap, H&R ARB's, B7 RS4 brakes, oil cooler, Tanoga short shift
  16. #13
    Banned
    Aug 2010
    823
    Post Thanks / Like
    hi dest plans are as follows in regards to to tuning and maintenance over the next 4 months, had to work it all out due to finances, i should be able to recoup some money back, people will want the injectors, downpipes and intercoolers
    Full service and full fluid change 655
    Spark plugs 70
    Oil filter 10
    Polen filter 15
    Air filter 50
    Fuel filter 15
    Engine oil 50
    Gear oil 65
    Differential oil 50
    Brake fluid 25
    Coolant 5
    Labour 300
    Initial tuning 2900
    Exhaust system 840
    Downpipes 1,000
    Stage 3 Remap 650
    Labour 410
    Final tuning 2640
    Fuel Pump 310
    Injectors 350
    Intercoolers 1500
    Labour 480
    This should see me past 500, hopefully the initial tuning will see me past 470, next year i may look at changing the turbos for hybrids as the base would have been pretty much set with the above
    here's some more pictures of the old girl
  17. #14
    Banned
    Aug 2010
    823
    Post Thanks / Like
    hopefully i might be able to save some money by buying second hand too
  18. #15
    eddieantifreeze's Avatar
    Jul 2011
    162
    Post Thanks / Like
    Looks good!
    If it makes you feel any better i have no clutch issues....
    97 Green 1.8T - Stage 1 R-Tech map - SOLD
    2001 B5 RS4 Avant - Misano Red
  19. #16
    Feb 2008
    2,548
    Post Thanks / Like
    Car looks great lovely colour. Where have the rs badges gone though?
    2000 AMK S3, Revo'd, forge 007p, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
  20. #17
    JS1500's Avatar
    Howdy
    Sep 2009
    Granite house, Granite City.
    1,159
    Post Thanks / Like
    Excellent. Class colour, is it called Santorin?
    I'm currently looking to trade up from S3 to RS4 myself (it's about bloomin' time!), so this info is great thanks.
    So, if anyone knows of a well cared-for B5 RS4 for sale please let me know!
    2003 Audi S3 BAM - Dolphin Grey; SOLD!
    Custom-Code Phase 1, Bilstein B8s and H&R springs, R32 rear ARB & poly bushes, Autobahn88 TIP, Pipercross panel filter, Forge 007p & yellow spring, 15mm & 10mm spacers, Brembo Max Grooved front discs & Ferodo DS2500 pads, Motul RBF600, Poly dog-bone bush, Bosch aero wipers, wind deflectors and Uniroyal RainSport 2s!
    254bhp @ 5,800rpm & 305lb/ft @ 3,400rpm.
    1975 MG Midget 1500 - Tahiti Blue;
    Recently rebuilt Stage Two engine, uprated everything else.
  21. #18
    Jan 2012
    9
    Post Thanks / Like
    Looks menacing even in standard form
  1. W3STY's Progress Thread
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 3 Days Ago, 23:00
  2. my avant progress thread
    By rawtor51 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4 Days Ago, 09:04
  3. my new s3 8l progress thread
    By s3schofield in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th October 2011, 17:23
  4. SY's PROGRESS THREAD
    By AGU-TURBO in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th August 2011, 22:56
  5. Progress Thread
    By MickM in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th May 2010, 21:29
