JBSAdrian S Flux
    JAJ
    Feb 2011
    Nottingham
    Post Thanks / Like
    Engine Oil in my RS4 B7
    Hi all, have recently purchased my RS4 B7 on a 2007 year which has been serviced to the avs, the engine oil appeared to be quite dirty to me so have just recently had a small service done. However after short distance the oil does not seem as clean to me as it should ? Is this normal for longlife oil or this engine ? Or should i be having it flushed out ( im thinking the engines a bit dirty inside ? ) I have always changed the oil and filter every 5000 miles on my 1.8t and the oil never really gets that dirty and was going to do the same with this one, is that about right ? Any advice would be appreciated
    PetrolDave's Avatar
    Nov 2003
    U.K.
    814
    Post Thanks / Like
    The oil in my RS4 stays clean for about 6000-7000 miles and only then starts getting dirty, and the oil consumption starts rising rapidly - so I know it's time for an oil change then.
    Sounds like you roil is getting dirty much quicker than that.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0200) with AMI (250GB hard disk), Bluetooth + HTC Touch HD
    Jul 2010
    Kent, UK
    15
    Post Thanks / Like
    Oil stays clean in my RS4, although it does like to eat oil.. I believe this is pretty normal for these cars to need a top-up every 3-4k miles so I am not going to loose any sleep. Seems to drink it quicker if I drive it like I stole it :D
    Rob Bentley
