Chris NottAH Fabrications
Results 1 to 17 of 17
Like Tree3Likes
  • 1 Post By 45bvtc
  • 1 Post By Veneeringman
  • 1 Post By 45bvtc
Thread: new tyres time
    Dave Hedgehog's Avatar
    Apr 2012
    266
    new tyres time
    i need a pair of 255 MPSS for the front, any cheap places you have used?, im based next to brands hatch
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,254
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Camskill, then I get a local garage to fit them - I've always found that to be the cheapest option tbh.
    I have a very reputable tyre man around the Medway area that I can PM you details on if you require?
    He's a Litchfield/GTR specialist and has a full 4wd hunter set up for alignment and tyre changes so your car/allys will be in great hands (Machine used to change tyres has no metal to metal contact)
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    Apr 2012
    266
    Quote Originally Posted by kwistof View Post
    that sounds perfect
    these seam to be the cheapest
    https://secure.tyreleader.co.uk/?t=tyre&i=402685&q=2
    MBK
    MBK's Avatar
    May 2012
    Neath
    1,155
    Excellent price, I'd go with that deal you will enjoy the difference the MPSS make.
    Apr 2012
    266
    can you give me his details pwz
    Apr 2012
    266
    all booked in, thanks for that
    Apr 2012
    266
    Quote Originally Posted by Dave Hedgehog View Post
    all fitted, i can 100% recomend sly and his magic hunter alignment machine, its total withcraft!
    i knew the conti's where terrible and close to their wear bars but i have never had a tyre swap thats improved turn in so drastically, it feels like a 50% increase, they seem to ride better and are less prone to tramlining
    once they have a couple of heat cycles in them i will give them so stick
    MBK
    MBK's Avatar
    May 2012
    Neath
    1,155
    Great improvement isn't it? It's 90% of the improvement you get from true track rubber like R888s without the compromise in the wet.
    The hammering the MPSS will stand on track is equally remarkable, you'd be through 2 sets of R888s in the same number of laps. I look forward to trying a set of MPSCups soon too because they really must be something else.
    Apr 2012
    266
    Apr 2012
    266
    oh well looks like i will have to replace the backs early with MPSS's. There is now such an imbalance of grip front to back that the back is all over the place, only the ESP saved it this morning ...
    Conti Tyres - "all the cost with none of the performance"
    kwistof's Avatar
    Jun 2010
    SE Kent
    2,254
    That's good to hear Dave
    Just need to sort my summer tyres out now and get my motor up to his premises to work his magic
    2000 S3 APY
    KKM
    KKM's Avatar
    May 2008
    Aberdeen
    89
    Out of curiosity, what size combo did you go for?
    I have 235/35 on the front and 225/35 on the rear.....I stuck with this sizes when I fitted winters, but I will be due to get new 'summer tyres' as spring approaches but want to make sure I go for the correct set up.
    cheers
    Kev
    RS3 Suzuka Grey - Black optic pack
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,281
    Quote Originally Posted by KKM View Post
    "but want to make sure I go for the correct set up."
    With 225s on the rear Kev then you have the correct Audi RS3 set-up.
    Only go for 235s on the back if you're ready to accept 'some' tyre to wheel arch fouling on full compression.
    I've 235s on the rear, winter and summer, and they do occasionally rub; but also give more rim protection than a 225.
    Veneeringman likes this.
    Veneeringman's Avatar
    Bazinga
    Aug 2010
    Back in the UK
    610
    I must admit John I'm contemplating getting 2 new continentals for the rear in 235 size because as you say the 225's offer zero rim protection.
    45bvtc likes this.
    2012 Misano Red RS3 / Bucket seats Heated front & Rear / Aluminium Styling Pack / Bose / RNS-E / Bluetooth / Mobile phone prep low / AMI / Reversing Sensors / LED number plate lights / Led interior light pack / VCDS / Cruise Control / Exclusive Inlays / Auto Lights & Wipers / 8.5J fronts / extended leather / Michelin Pilot super sport tyres / and a few other things
    Apr 2012
    266
    Quote Originally Posted by Veneeringman View Post
    i was considering 235s for exactly the same reason, although the MPSS rim protection does not stick out as far but it is much more substantial in construction
    will have to think on this
    dbm
    dbm's Avatar
    Preston, Lancs
    511
    I have to say, after putting my summer wheel and tyres (Eagle F1) back on the car I've fallen in love with it again. The levels of poise and grip and fantastic. It really finishes off the car for me.
    RS3 | TTS | A3 3.2Q | S3(8L)
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,281
    Works for me Sean, winter Vredesteins and summer Continentals are both 235/35 on the rear
    And I'm still running 39/37 tyre pressures: much better ride/bite/even wear across the tread with both summer and/or winter tyres
    And the summer rubber (with 8.5J fronts) now back on BLUEY (yesterday) but am leaving the Vredesteins on the TT as snow is now a possible for this weekend.
    KKM likes this.
  1. Time for new tyres which ones ?
    By tri3hrs in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th September 2012, 12:55
  2. New tyre Time
    By edition in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th August 2008, 22:08
  3. Time for new tyres - any suggestions?
    By Keef in forum Handling
    Last Post: 15th November 2006, 20:18
  4. new tyres
    By simonhenchie in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th July 2003, 10:41
  5. need new tyres
    By pwnorman in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th May 2003, 08:51
