AH FabricationsVolks Autos
Results 1 to 15 of 15
Like Tree12Likes
  • 2 Post By 45bvtc
  • 3 Post By Mr_Freeze
  • 1 Post By PopGun
  • 1 Post By Mr_Freeze
  • 3 Post By 45bvtc
  • 2 Post By Veneeringman
Thread: Sport Button....
    KKM
    KKM's Avatar
    May 2008
    Aberdeen
    89
    Sport Button....
    All,
    Noticed this last night on my drive home.
    Normal procedure is to start car and then straight away hit the 'S' button......with the secondary by-pass pipes, the noise is awesome...
    However, my problem at the moment is even with the 'S' button on, there is no change in my exhaust note?
    Thoughts please.....???
    cheers
    Kev
    RS3 Suzuka Grey - Black optic pack
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,295
    With the engine running at idle rpm, Kev: get some 'sensitive' person to stand at the exhaust outlets to check the gas-flow from the exhaust tail pipe(s) with the 'S' button: 1) de-activated (1-outlet), and 2) activated (2-outlets).
    There will be a difference in both flow and noise, Kev; I'll leave you to find out.
    But if there is NO difference then off to an Audi dealer you should go as it could be either: a) electrical, or b) mechanical, but the flap valve in the exhaust tailpipes isn't functioning.
    KKM and DAYTONA500 like this.
    DAYTONA500's Avatar
    Jul 2013
    In a world of my own.
    451
    Just to add its normal that the valve doesn't operate straight away when the choke is on i.e. on higher revs at idle when the engine is cold.
    KKM
    KKM's Avatar
    May 2008
    Aberdeen
    89
    Quote Originally Posted by DAYTONA500 View Post
    Thanks for the feedback guys. I will try this out tonight.
    When I said hit the button straight away, it was of course during my drive along my road out of the village. Hence why I noticed a massive difference i.e - it's a nice deep barble along the country roads enroute to work normally with the sport button 'on'
    Will check everything over and report back.
    cheers
    Veneeringman's Avatar
    Bazinga
    Aug 2010
    Back in the UK
    641
    I've noticed that as well, on start up from cold the valve must open up fully for a couple of minutes, as pressing the sport button makes no difference to the exhaust tone.
    2012 Misano Red RS3 / Bucket seats Heated front & Rear / Aluminium Styling Pack / Bose / RNS-E / Bluetooth / Mobile phone prep low / AMI / Reversing Sensors / LED number plate lights / Led interior light pack / VCDS / Cruise Control / Exclusive Inlays / Auto Lights & Wipers / 8.5J fronts / extended leather / Michelin Pilot super sport tyres / and a few other things
    Mr_Freeze's Avatar
    Feb 2013
    Trowbridge, originally from Leeds
    372
    Quote Originally Posted by Veneeringman View Post
    No it's the other way round, when it's cold pressing the S does nothing, but the valve is closed. It's only after the initial fast idle that the button comes into play and the valve will open when pressed.
    KKM, 45bvtc and DAYTONA500 like this.
    One of 750 RS3, Ibis White, Buckets, Privacy glass, Black styling, Cruise control, Bose, Scorpion Cat Back Non-Resonated exhaust system.
    Bazinga
    Aug 2010
    Back in the UK
    641
    Quote Originally Posted by Mr_Freeze View Post
    I stand corrected !
    klauster's Avatar
    Jan 2007
    Leeds
    1,140
    I always wait for the car to warm up properly before pushing the S button, otherwise too much temptation to floor it
    www.SubZerosystems.co.uk - IT Consultancy
    KKM
    KKM's Avatar
    May 2008
    Aberdeen
    89
    checked the 'flaps' so to speak last night, but no difference in flow or noise. button on, but off, no change.
    phone call to Audi happening soon.....
    thanks for your help
    Sep 2010
    30
    Check the pipe going into the flap/exhaust isn't bent.
    The flap opens using pressure. If the pipe leading to the rear exhaust tail pieces is bent it wont open the flap which is in the left tail piece.
    KKM likes this.
    Mr_Freeze's Avatar
    Feb 2013
    372
    I stand corrected !
    No, you may sit!
    45bvtc likes this.
    KKM
    KKM's Avatar
    May 2008
    Aberdeen
    89
    So went to the local Audi dealership today and they have booked my car in for 2 weeks time to review my problem.....
    Should I ask for any other 'updates' to be carried out at the same time?
    cheers
    Kev
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,295
    Quote Originally Posted by KKM View Post
    cheers
    Kev
    Kev, you should ask what updates are listed for your 'own' car; they WILL be listed on the Audi system against your own Vehicle Identification Number (VIN) No:.
    The 'updates' listed on the Audi Forum(s) are NOT applicable to all cars, which is where much consternation is coming from.
    Get your dealer to review ALL updates applicable to your own car, for sure they'll not be the same as they were/are for mine.
    KKM, Veneeringman and DAYTONA500 like this.
    Bazinga
    Aug 2010
    Back in the UK
    641
    I'm praying Manchester Audi have the good sense to carry out any applicable updates while mines in their workshop.
    KKM
    KKM's Avatar
    May 2008
    Aberdeen
    89
    Only good thing about the sport button being out of action is increased MPG figures..... hit over 30 at the weekend...... first time in a long while that's been displayed.
  1. sport button - exhaust valve/flap
    By PopGun in forum RS3 Forum
    Last Post: 23rd February 2013, 03:32
  2. Sport button & infating seats
    By Sno in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 20th October 2009, 16:35
  3. SPORT button not working??
    By gjrquattro in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 4th October 2008, 13:24
  4. 93 audi 90 sport button
    By hcore in forum Classic Audi Forum
    Last Post: 8th July 2004, 12:10
  5. Welcome to RS4 forums at audi-sport
    By Administrators in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th January 2003, 13:44
Tags for this Thread
