AH FabricationsVolks Autos
Results 1 to 13 of 13
Like Tree8Likes
  • 2 Post By 45bvtc
  • 1 Post By Veneeringman
  • 1 Post By 45bvtc
  • 1 Post By boozyjay
  • 1 Post By 45bvtc
  • 1 Post By 45bvtc
Thread: Tyres
    boozyjay's Avatar
    Nov 2012
    16
    Tyres
    I know this has been talked about so many times on here - and to be honest I hate the pesky things - but my RS3 has been into Audi for some warranty work and they have told me the tyres are worn. I've got Contisports 225/35zr19's all round - I thought they were 235's on the rears originally and 225's on the front - or was that the other way round?, maybe someone can correct me on this?
    So do I stick with the Continentals or change to another tyre? I'm not a track day hooligan and to be honest I'm not a fast driver so any help will be appreciated.
    Also, do I need to go 235 on rear, or even 235 all the way round - will they go straight on? or do I stick with the 225's all round.
    Regards
    Jason.
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,093
    You should NOT have 225/35s on the FRONT - NO WAY!
    All data on your tyre data sticker...
    A lot of guys have already changed to 235/35 Goodyear F1s all round with A1 feedback.
    As you say, it "has been talked about so many times on here", so there's lots of information posted.
    Veneeringman's Avatar
    Aug 2010
    Back in the UK
    419
    As John Say's 235 or 255 (with 8.5J Alloys) on the front, can't understand why someone would use 225's all round though !
    Try Camskill, My Tyres or Black Circles for the best prices, as mentioned the Goodyear F1's have good feedback (had them on my previous S3) also do Michelin Super sports and if your not bothered / Happy with the conti's just put them on with the correct spec Front's.
    45bvtc likes this.
    2012 Misano Red RS3 / Bucket seats Heated front & Rear / Aluminium Styling Pack / Bose / RNS-E / Bluetooth / Mobile phone prep low / AMI / Reversing Sensors / LED number plate lights / Led interior light pack / VCDS / Cruise Control / Exclusive Inlays / Auto Lights & Wipers / 8.5J fronts / extended leather /
    boozyjay's Avatar
    Nov 2012
    16
    Thanks for the tips. Not sure why it had 225's on the front. Had it 12 months now from Audi approved so may speak to Dealer as to why - not that it will do much as I've got to change them now anyway.
    KKM
    KKM's Avatar
    May 2008
    Aberdeen
    82
    How many miles have you covered? are they worn evenly or have the got chunks of rubber out of them?
    cheers
    KKM
    RS3 Suzuka Grey - Black optic pack
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,093
    Just a thought: I do find the tyre pressures of 41/39 a tad too hard, with high-wear in the centre of the tyre, especially on the fronts.
    This centre high-wear was noticeable from new with the standard 8J front rim and 235/35 tyres (running 41psi).
    When I changed last year to the 8.5J FRONT rim with a 255/30 tyre (and put the original 8J FRONT and 235/35 on the rear) the centre high-wear pattern was quickly noticed, polishing off the moulding fraises within the first 100-miles or so.
    Note: always a good test to follow the 'fraise' wear pattern on a new set of tyres as it can tell you lots about the cars set-up.
    I digress: I now run 39/37 front/rear pressures and find that both the wear and ride are much improved - and I'm still on Continentals.
    KKM likes this.
    boozyjay's Avatar
    Nov 2012
    16
    Quote Originally Posted by KKM View Post
    cheers
    KKM
    Even wear and there is a split on the inner wall on one of them.
    Just ordered the Continentals again - but with 235's on the front
    45bvtc likes this.
    boozyjay's Avatar
    Nov 2012
    16
    Quote Originally Posted by 45bvtc View Post
    I'll bear that in mind John when I change them. Thanks for the tip.
    45bvtc likes this.
    Mar 2012
    15
    Hi all
    Been reading a lot of the tyre posts and I am after some advice on tyres ??
    I need 2 new fronts called Audi for a quote to be told I have to have the same make front and rear ?
    Is this correct ? if so why ??
    Thanks RSjack
    rezulteo's Avatar
    Sep 2011
    206
    Follow rezulteo On Twitter Add rezulteo on Facebook
    Its because of safety that the tyres should be the same front and back. It will help avoid uneven wear and will give you better adherence. You can find the correct tyres here Tyres, compare tyre prices. Which tyre? Where to buy? and find retailers close by here Tyres UK. To buy and fit tyres in UK. rezulteo
    Hope this helps.
    All tyres for Audi and tyre news, advice, tests and comparisons on http://www.rezulteo-tyres.co.uk
    Follow us on Twitter !
    Like our Facebook page !
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,093
    Quote Originally Posted by RSjack View Post
    Hi all
    Thanks RSjack
    See Post #2: then find your own label - located in the inside edge of the driver door.
    To be fair to Audi, you need to tell Audi who! If it's the meeter and greeter then I wouldn't expect him to know, a salesman either; but if that's a technical person then you should name and shame him/her...
    Why you'd want to purchase tyres from Audi, however, is your own decision...
    DAYTONA500 likes this.
    Mar 2012
    15
    hi
    this was Southampton Audi`s specialist tyre man who said I have to "have same front and rear as its the RS3"?
    only called them to ask for quote and for tracking quote. £195 each all in couldn't tell me tracking price but needed car for 1 hour to do this plus cost of tracking. is it ok to fit say Goodyear's on the front ??
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,093
    hi
    Yes, Goodyear F1's seem to be the preferred choice for most RS3 owners, however, I "may" be staying on Continentals when it comes around for mine to be changed but both the Goodyear F1 and Michelin Pilot Sport will be considered too.
    However, your original tyres were ContiSportContact 5P on 19-inch x 8J rims:
    At the FRONT: 235 x 35 x ZR 19 91Y Extra Load
    At the REAR: 225 x 35 x ZR 19 88Y Extra Load
    A note of caution: some cars (mine) are on an 8.5J FRONT wheel with a 255 x 30 x ZR 19 91Y Extra Load tyre; and maybe this is why I don't have the same issues others have with the Continentals.
    Daytona3 likes this.
  1. TYRE WEAR - ONE TYRE ONLY -SEVERE!!
    By fraz in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th April 2003, 09:18
  2. MOVED: TYRE WEAR - ONE TYRE ONLY -SEVERE!!
    By fraz in forum General Chat
    Last Post: 28th March 2003, 12:18
  3. What tyres for my S3 ??
    By sidicks in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th March 2003, 15:54
  4. bumps in tyres
    By phloat in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2003, 09:08
  5. Tyres?
    By Moresauce in forum Other Brands & Models
    Last Post: 16th January 2003, 19:57
