AH FabricationsBadger5
    Oct 2013
    Replacement front disks
    Morning all
    I have had the brake recall and front vents done about 6 months ago. This cured both the brake squeal most people get and brake judder
    But after a track day the judder came back. Dealer took one look at the disks and pads and said there was no way that Audi would replace them as it had been tracked.
    I then had the front disks skimmed and some brembo pads fitted which did sort the brake judder out.
    But after just a few minutes of light braking on another track day , the judder came back. It gets worse with harder braking but is always there even under light normal braking on the road
    So. My thoughts were to junk the stock disks and get upgraded ones that work with stock callipers. Any thoughts on this approach and the make to go for?
    I'm pretty sure it's the front disks as applying the handbrake doesn't make it happen and the tremor is felt through steering wheel. Would my diagnosis be correct?
    MBK
    MBK's Avatar
    May 2012
    Neath
    1,156
    Here you go, a whole thread about this very subject here, with suggested replacements and some fitting pictures:
    Upgrading discs and pads - options?
    Oct 2013
    Many thanks for the reply and pointing me in the right direction. Are you happy with your upgrade now you’ve had them for a while?
  1. Replacing Front plates!
    By Aldo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd June 2006, 21:54
  2. Replacement front Discs
    By john2garden in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th May 2006, 09:25
  3. Replacing front discs
    By mebrown001 in forum Tuning
    Last Post: 29th June 2005, 13:14
  4. Components to replace fronts in S3
    By monty77 in forum In-Car Entertainment
    Last Post: 19th December 2004, 21:11
  5. Replacing front / rear BOSE speakers in new A3
    By cheechy in forum In-Car Entertainment
    Last Post: 31st August 2004, 18:21
