AH FabricationsVolks Autos
Results 1 to 8 of 8
Like Tree7Likes
  • 4 Post By Mr_Freeze
  • 3 Post By dbm
Thread: Silly Question Time
    Dec 2013
    Oxfordshire
    29
    Question Silly Question Time
    Ok, flame suit on ............. The RS is the first car I've ever owned thats automatic (semi). I notice that there is a certain amount of "creep" when on tickover so in order to stay stationary I have to keep my foot on the brake. Common sense tells me that too much of this could eventually burn out the clutch so I've started knocking it into neutral when sitting at traffic lights etc. Is it the done thing to stick it in neutral while stationary for more than a few seconds or am I worrying for nothing ?
    monkeyboy_marcus's Avatar
    Aug 2012
    Sevenoaks, Kent
    263
    That's what I do mate, seems to be what neutral's for… Park when going nowhere, D/S when engaged etc.
    Dave Hedgehog's Avatar
    Apr 2012
    225
    absolute no need to do this, i put 50k miles on my R32 DSG in very heavy SE london traffic and had no issues with the box or the clutch, this would be hundreds of thousands of "creeps" and thousands of 0-30 launches
    klauster's Avatar
    Jan 2007
    Leeds
    1,122
    In my experience of RS cars, yes use P or N when stationary as you are more likely to transfer brake pad deposits on to the discs which in time will cause vibrations
    www.SubZerosystems.co.uk - IT Consultancy
    Aug 2012
    Sevenoaks, Kent
    263
    Quote Originally Posted by Dave Hedgehog View Post
    Can't do any harm though right? I also pop it into neutral when decelerating from warp speed coming up to roundabouts etc. No point fighting the engine as well as momentum/inertia (John will be able to define the difference!)...
    Apr 2012
    225
    Quote Originally Posted by monkeyboy_marcus View Post
    opps: your talking about on the move, no I would never do that, apart from anything else it wastes fuel, i also run down the box as i pull up if driving spiritedly
    when stationary unless engaging the clutch caused a slight wear to the clutch plate then no I can not imagine it doing any harm but i am sure an expert can advise us properly
    i certainly wont be doing it, unless of course the brakes where hot, which they wont be in normal driving or heavy traffic
    Mr_Freeze's Avatar
    Feb 2013
    Trowbridge, originally from Leeds
    348
    I would never put a car in neutral while it's moving, whether it's a manual or an auto. It's a bad practice as far as I'm concerned.
    While the car is in neutral, you lose some level of control over the car.
    kwistof, Kelza, 45bvtc and 1 others like this.
    One of 750 RS3, Ibis White, Buckets, Privacy glass, Black styling, Cruise control, Bose, Scorpion Cat Bypass pipes.
    dbm
    dbm's Avatar
    Preston, Lancs
    485
    On the contrary, I probably screwed the mechatronic control unit in my first DSG car by doing this on a regular basis. It confuses the car greatly and introduced bad shunting (the clutches engaging and disengaging repeatedly) when pulling away.
    Only use N when stationary; I only use it if I think I will be stopped for more than 5-10 seconds.
    L1ARR, 45bvtc and DAYTONA500 like this.
    RS3 | TTS | A3 3.2Q | S3(8L)
  1. Silly Question Time Again - S3 Climate Control.
    By taylorc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st May 2010, 16:34
  2. silly question time
    By rossbrownlee in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th February 2010, 19:13
  3. Silly Question But
    By Markey in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th February 2005, 17:30
  4. A silly question
    By David_Moon in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th November 2004, 00:27
  5. Silly Question's From A Soon-2-B S3 Owner!
    By Manics in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2003, 23:48
